NethServer Version: 7.9.2009
Module: Nextcloud
Hi - I am having some trouble getting Nextcloud to work with Mariadb 10.3. I have installed MariaDB using the stephdl repository and have phpMyAdmin installed. I can connect to the MariaDB database using phpMyAdmin on port 3313, and the older version on 3303.
I have loaded a copy of the nextcloud database into the mariadb server, added a user and given the user the same password, and let the user connect from %, localhost, 127.0.0.1, server.domainname.
I changed the configuration as follows:
config show rh-mariadb103-mariadb
rh-mariadb103-mariadb=configuration
LocalNetworkingOnly=no
MaxAllowedPacket=16M
TCPPort=3313
access=public
status=enabled
If I change the nextcloud configuration file to use 127.0.0.1 and 3313 as the database server host and port, nextcloud still connects to the old database. If I use server.domainname, I get an error in the nextcloud log that says the server is not allowed to connect.
I would like to get nextcloud onto a more recent database - but cannot figure out why I cannot get it to connect correctly. Any help appreciated.
