Hello,
when checking .tsv for groups and users, I see there is no data inside it
so how to active it? are there another place for backup possible to restore users and groups from it.
Best Regards
Usually accounts are exported when uninstalling an account provider, see sssd devel docs.
To force account export:
/etc/e-smith/events/actions/nethserver-sssd-export-accounts
I was Uninstall it before so why there is no info at:
/var/lib/nethserver/backup/users.tsv and /var/lib/nethserver/backup/groups.tsv
and what about backup,depends on .tsv files or using other methods?
and the command worked for me.
thanks
No, the Nethserver backup saves the config and the databases:
For AD (container):
Backups /var/lib/machines/nsdc/etc/samba and /var/lib/machines/nsdc/var/lib/samba
For LDAP:
Writes config/data to /var/lib/nethserver/backup with slapcat for backup.
How to show or extract the files that contains users & groups?
thanks
