Here are some helpful scripts and commands for use on RPI OS
Scripts
installzram.sh
#!/usr/bin/env bash
sudo wget -O /usr/bin/zram.sh https://raw.githubusercontent.com/novaspirit/rpi_zram/master/zram.sh
sudo chmod +x /usr/bin/zram.sh
grep -qxF '/usr/bin/zram.sh &' /etc/rc.local || sed -i "/exit 0/i\/usr/bin/zram.sh &" /etc/rc.local
joinnethad.sh
#!/usr/bin/env bash
echo -e
echo "Please enter the password for admin"
echo -e
wait
read -r adpass
echo -e
echo "Please enter your domain name"
echo -e
wait
read -r domain
#Updating file /etc/hosts
echo "127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
127.0.1.1 $(cat /etc/hostname).$domain $(cat /etc/hostname)" > /etc/hosts
#Updating file /etc/sudoers
grep -qxF '%domain\ admins ALL=(ALL:ALL) ALL' /etc/sudoers || echo '%domain\ admins ALL=(ALL:ALL) ALL' >> /etc/sudoers
#Updating RPI
sudo apt -y update
#Installing krb-user
export DEBIAN_FRONTEND=noninteractive
sudo -E apt -y -qq install krb5-user
wait
#Updating file /etc/krb5.conf
echo "[libdefaults]
default_realm = AD.${domain^^}
[login]
krb4_convert = true
krb4_get_tickets = false" > /etc/krb5.conf
#Installing libpam-sss
sudo -E apt -y -qq install libpam-sss
wait
#Installing libpam-mount
sudo -E apt -y -qq install libpam-mount
wait
#Updating file /etc/pam.d/common-session
echo "#
# /etc/pam.d/common-session - session-related modules common to all services
# This file is included from other service-specific PAM config files,
# and should contain a list of modules that define tasks to be performed
# at the start and end of sessions of *any* kind (both interactive and
# non-interactive).
# As of pam 1.0.1-6, this file is managed by pam-auth-update by default.
# To take advantage of this, it is recommended that you configure any
# local modules either before or after the default block, and use
# pam-auth-update to manage selection of other modules. See
# pam-auth-update(8) for details.
# here are the per-package modules (the "Primary" block)
session [default=1] pam_permit.so
# here's the fallback if no module succeeds
session requisite pam_deny.so
# prime the stack with a positive return value if there isn't one already;
# this avoids us returning an error just because nothing sets a success code
# since the modules above will each just jump around
session required pam_permit.so
# and here are more per-package modules (the "Additional" block)
session required pam_unix.so
session optional pam_sss.so
session optional pam_systemd.so
session optional pam_chksshpwd.so
session required pam_mkhomedir.so skel=/etc/skel/ umask=0022
# end of pam-auth-update config" > /etc/pam.d/common-session
#Installing realmd
sudo -E apt -y -qq install realmd
wait
#Updating file /etc/realmd.conf
echo "[active-directory]
os-name = Raspbian
os-version = $(cat /etc/debian_version)
[service]
automatic-install = yes
[users]
default-home = /home/%u
default-shell = /bin/bash
[ad.$domain]
user-principal = yes
fully-qualified-names = no" > /etc/realmd.conf
#Installing Prerequisites
sudo apt -y install ntp python3-pip sssd adcli libsss-sudo cifs-utils smbclient sssd-tools samba-common packagekit samba-common-bin samba-libs libnss-sss oddjob oddjob-mkhomedir packagekit
wait
#Updating file /etc/sssd/sssd.conf
echo "[sssd]
domains =
config_file_version = 2
services = nss, pam
[$domain/ad.$domain]
ad_domain = ad.$domain
krb5_realm = AD.${domain^^}
realmd_tags = manages-system joined-with-adcli
cache_credentials = True
id_provider = ad
krb5_store_password_if_offline = True
default_shell = /bin/bash
ldap_id_mapping = True
use_fully_qualified_names = True
fallback_homedir = /home/%u
access_provider = ad
auth_provider = ad
chpass_provider = ad
ldap_schema = ad
dyndns_update = true
dyndns_refresh_interval = 43200
dyndns_update_ptr = true
dyndns_ttl = 3600" > /etc/sssd/sssd.conf
#Updating file /etc/ntp.conf
echo "# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
# Leap seconds definition provided by tzdata
leapfile /usr/share/zoneinfo/leap-seconds.list
# Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
# You do need to talk to an NTP server or two (or three).
server time.cloudflare.com
# pool.ntp.org maps to about 1000 low-stratum NTP servers. Your server will
# pick a different set every time it starts up. Please consider joining the
# pool: <http://www.pool.ntp.org/join.html>
pool 0.debian.pool.ntp.org iburst
pool 1.debian.pool.ntp.org iburst
pool 2.debian.pool.ntp.org iburst
pool 3.debian.pool.ntp.org iburst
# Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
# details. The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
# might also be helpful.
# Note that "restrict" applies to both servers and clients, so a configuration
# that might be intended to block requests from certain clients could also end
# up blocking replies from your own upstream servers.
# By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery limited
restrict -6 default kod notrap nomodify nopeer noquery limited
# Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict -6 ::1
# Needed for adding pool entries
restrict source notrap nomodify noquery
# Clients from this (example!) subnet have unlimited access, but only if
# cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
# If you want to provide time to your local subnet, change the next line.
# (Again, the address is an example only.)
#broadcast 192.168.123.255
# If you want to listen to time broadcasts on your local subnet, de-comment the
# next lines. Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient" > /etc/ntp.conf
#Restarting the NTP service
sudo systemctl restart ntp
#Discovering Realm
realm discover ad.$domain
echo "$adpass" | kinit -V admin
#Joining domain
echo "$adpass" | realm join -U admin@AD.${domain^^} ad.$domain
wait
echo -e
echo "Congratulations $(cat /etc/hostname) is now part of ad.$domain"
echo -e
This script uses time.cloudflare.com as NTP server
- to leave domain simply run
realm leave
if you need to change the hostname (ie to change from default raspberrypi to yourhostname) run this command before running joinnethad.sh
sudo hostnamectl set-hostname yourhostname
Commands
- To disable Bluetooth
grep -qxF 'dtoverlay=disable-bt' /boot/config.txt || echo 'dtoverlay=disable-bt' >> /boot/config.txt
using grep -qxF 'dtoverlay=disable-bt' /boot/config.txt || before cmd makes sure the line won’t be appended if it’s already there
- To disable HDMI (if were using it as headless)
/usr/bin/tvservice -o
or If you want this to be applied also at boot time
grep -qxF '/usr/bin/tvservice -o' /boot/config.txt || sed -i "/exit 0/i\/usr/bin/tvservice -o" /boot/config.txt
- To update firmware
sudo apt -y update && sudo rpi-eeprom-update && sudo apt -y full-upgrade
- To enable Root access on ssh
grep -qxF 'PermitRootLogin yes' /etc/ssh/sshd_config || echo "PermitRootLogin yes" >> /etc/ssh/sshd_config && sudo systemctl restart ssh.service && sudo passwd root
