Excuse me for the stupid question. But I’m not very experienced with linux.
I’m testing, when I install neth on a PC with single-hd, it automatically creates partition: /root (50 gb), /swap (based on RAM) and /home (with the remaining Gb of HD ).
In the status_disk usage, I see only 50 Gb of /root, if l active ftp, uses /root space, if I active emails uses /root space. How do I use the /home space?
The other installations I manually resized /root, but I don’t think it’s the correct procedure.
Is there a standard way to handle partitions?
Thank you
Maybe I did not understand the question.
Did you install nethserver from community iso? I just reinstalled it on single hdd and standard installation assigns all the space to “/”.
The default folder containing the data and settings in nethserver is /var/lib/nethserver
Install from iso. I do a custom installation, split the disk into /root 50 Gb, /swap based on ram memory and the rest of the disk /home. Do I miss something when I install it?
Unattended Installation: All the space of the hd is assigned to /root. A critical error on the dashboard is reported on RAID1 (sda1 / sda2) … ??? I have only one hd.
