NethServer Version: NethServer release 7.4.1708 (Final)
Module: UPS
Hi all, I tried to configure my UPS Riello with NS dedicated panel.
I have selected right driver (riello_ser) and device USB (auto) and then save. However,
I found this error in the panel: Task complete with error (#exitcode)
I have searched info a journalctl and I found this:
collectd[9889]: read-function of plugin `nut' failed. Will suspend it for 640.000 seconds.
collectd[9889]: nut plugin: nut_read_one: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
upsmon[9934]: UPS [UPS@127.0.0.1]: connect failed: Connection failure: Connection refused
The settings in ups/ folder are:
/etc/ups/ups.conf
pollinterval = 10
[UPS]
driver = riello_ser
port = /dev/ttyUSB0
/etc/ups/upsd.conf
LISTEN 0.0.0.0
Could anyone have tips on how to fix the problem?
Thanks,
Pasquale
