I’ve a 7.6.1810 (final) server up-to-date but no system upgrade button is appeared. If I try to do it manually :
yum clean all
yum update
signal-event software-repos-upgrade
I have a probleme
/etc/yum/vars/nsrelease -> “7.6.1810” becomes /etc/yum/vars/nsrelease -> “7.5.1804” and I get :
" Loaded plugins: changelog, fastestmirror, nethserver_events
Could not retrieve mirrorlist http://mirrorlist.nethserver.org/?release=7&repo=ce-base&arch=x86_64&nsrelease=7.5.1804 error was
14: HTTP Error 404 - Not Found …"
Could you help to get 7.7 version ?
Thanks in advance
Samuel
I push the right version into /etc/yum/vars/nsrelease and I did a yum clean all, yum update and I got the update successfully. But I still have the same issue after the command signal-event software-repos-upgrade I get “7.7.1804” in /etc/yum/vars/nsrelease. overwrite by “7.5.1804”.
