alep
(Alessandro Polidori)
December 12, 2017, 1:07pm
1
Hello there, I’ve tried new upgrade version of nextcloud 12.0.4 and it seems to work correctly.
Someone else ?
Here is the rpm (nethserver-nextcloud-1.1.8-1.3.pr23.g9d1e168.ns7.noarch.rpm) created by nethbot
As you can see here nextcloud 12.0.4 has over 50 fixes !
alefattorini
(Alessio Fattorini)
December 12, 2017, 1:24pm
2
Tagging here @gerald_FS @dnutan @lucian @Drake @happnatious1
Would you like to help us to test the new version? I would appreciate it
mrmarkuz
(Markus Neuberger)
December 12, 2017, 2:28pm
3
alep:
Here is the rpm
Yeah, Nextcloud update!!! I tried it now…
Is there some repo, I am missing?
yum install http://packages.nethserver.org/nethserver/7.4.1708/autobuild/x86_64/Packages/nethserver-nextcloud-1.1.8-1.3.pr23.g9d1e168.ns7.noarch.rpm
Error: Package: nethserver-nextcloud-1.1.8-1.3.pr23.g9d1e168.ns7.noarch (/nethserver-nextcloud-1.1.8-1.3.pr23.g9d1e168.ns7.noarch)
Requires: nextcloud >= 12.0.4
Installed: nextcloud-12.0.3-1.el7.noarch (@nethserver-base)
nextcloud = 12.0.3-1.el7
Available: nextcloud-10.0.4-2.el7.noarch (epel)
nextcloud = 10.0.4-2.el7
Updating manually worked, after that I could update via web UI…
cd /usr/share/
curl -o nextcloud-12-latest.tar.bz2 https://download.nextcloud.com/server/releases/latest-12.tar.bz2
tar -xvjf nextcloud-12-latest.tar.bz2
mkdir nextcloud/data # not needed on update
chown -R apache:apache nextcloud
rm nextcloud-12-latest.tar.bz2
from here:
Install NextCloud 12 on CentOS 7 today following this tutorial. NextCloud is a Dropbox-like solution for self-hosted file sharing, calendar and more.
Est. reading time: 8 minutes
Now it’s updated
but some errors showing up, maybe because I didn’t use the RPM.
Some files have not passed the integrity check. Further information on how to resolve this issue can be found in our documentation. (List of invalid files… / Rescan…)
The “Strict-Transport-Security” HTTP header is not configured to at least “15552000” seconds. For enhanced security we recommend enabling HSTS as described in our security tips.
dnutan
(Marc)
December 12, 2017, 3:59pm
4
As @mrmarkuz found out we miss a direct link to nextcloud rpm package, or upload them to testing repo.
alep
December 14, 2017, 11:43am
5
alefattorini
(Alessio Fattorini)
December 18, 2017, 3:44pm
6
Looks tested by @dnutan Right? Can we close?
alep
December 18, 2017, 5:07pm
7
I think yes.
@giacomo or @davidep ?
giacomo
(Giacomo Sanchietti)
December 18, 2017, 5:35pm
8
Please be patient I will close it as soon as the update has been released.
giacomo
December 19, 2017, 5:33pm
9
Thank you all for the work!
The updates has been released few seconds ago
