Upgrade nethserver 7.3 to 7.5.1804 (final), help nextcloud
NethServer Version: 7.3 to 7.5 final
Module: your_module nextcloud 12.x to 14.x
Please help me,
I have updated from version 7.3 to 7.5 everything ok
the nextcloud module from version 12 to version 14 has also been updated.
Now when I connect to nextcloud web this window appears to me telling me that it is necessary to do an update, but it is better to do it from the command line
Please tell me what command do I have to launch in the console to avoid risking anything?
Thank you
Nextcloud upgrade might have failed at some step (/var/log/messages can bring some clues).
If you try to finish the upgrade from command line it could reveal if there’s any error preventing normal operation:
su - apache -s /bin/bash -c "source /opt/rh/rh-php71/enable; cd /usr/share/nextcloud/; php occ upgrade"
hello,
thanks for your repaly,
on the web or the cmd i recice this error:
Updates between multiple major versions are unsupported
i have reload the backup the virtual machine waiting to understand what to do.
Hello
Faced same issue long ago on a test machine. Here’s what worked for me:
If solution does not apply to your case (i.e. no restore point) let me now. I’ve an old VM with the NS7.3 and Nextcloud 12 that I could use to reproduce your issue.
EDIT: reproduced your setup:
[root@server ~]# cat /etc/nethserver-release
NethServer release 7.3.1611 (Final)
[root@server ~]# rpm -q nextcloud nethserver-nextcloud
nextcloud-12.0.2-2.el7.noarch
nethserver-nextcloud-1.1.7-1.ns7.noarch
[root@server ~]# yum update
NethServer release 7.5.1804 (final)
nextcloud%20upgrade%20failed
…and solved like this:
[root@server ~]# yum --showduplicates list *nextcloud
Installed Packages
nethserver-nextcloud.noarch        1.2.7-1.ns7        @nethserver-updates
nextcloud.noarch                   14.0.3-1.el7       @nethserver-updates
Available Packages
nethserver-nextcloud.noarch        1.2.1-1.ns7        nethserver-base
nethserver-nextcloud.noarch        1.2.2-1.ns7        nethserver-updates
nethserver-nextcloud.noarch        1.2.3-1.ns7        nethserver-updates
nethserver-nextcloud.noarch        1.2.4-1.ns7        nethserver-updates
nethserver-nextcloud.noarch        1.2.5-1.ns7        nethserver-updates
nethserver-nextcloud.noarch        1.2.6-1.ns7        nethserver-updates
nethserver-nextcloud.noarch        1.2.7-1.ns7        nethserver-updates
nextcloud.noarch                   10.0.4-2.el7       epel
nextcloud.noarch                   13.0.2-1.el7       nethserver-base
nextcloud.noarch                   13.0.4-1.ns7       nethserver-updates
nextcloud.noarch                   13.0.5-1.el7       nethserver-updates
nextcloud.noarch                   13.0.6-1.el7       nethserver-updates
nextcloud.noarch                   14.0.0-1.el7       nethserver-updates
nextcloud.noarch                   14.0.1-1.el7       nethserver-updates
nextcloud.noarch                   14.0.3-1.el7       nethserver-updates
[root@server ~]# yum downgrade nethserver-nextcloud-1.2.4-1.ns7 nextcloud-13.0.6-1.el7
Resolving Dependencies
--> Running transaction check
---> Package nethserver-nextcloud.noarch 0:1.2.4-1.ns7 will be a downgrade
---> Package nethserver-nextcloud.noarch 0:1.2.7-1.ns7 will be erased
---> Package nextcloud.noarch 0:13.0.6-1.el7 will be a downgrade
---> Package nextcloud.noarch 0:14.0.3-1.el7 will be erased
Removed:
  nethserver-nextcloud.noarch 0:1.2.7-1.ns7      nextcloud.noarch 0:14.0.3-1.el7
Installed:
  nethserver-nextcloud.noarch 0:1.2.4-1.ns7      nextcloud.noarch 0:13.0.6-1.el7
[root@server ~]# yum update nethserver-nextcloud nextcloud
---> Package nethserver-nextcloud.noarch 0:1.2.4-1.ns7 will be updated
---> Package nethserver-nextcloud.noarch 0:1.2.7-1.ns7 will be an update
---> Package nextcloud.noarch 0:13.0.6-1.el7 will be updated
---> Package nextcloud.noarch 0:14.0.3-1.el7 will be an update
Updated:
After that, Nextcloud was working but had to manually update some apps from Nextcloud apps interface, logout, login and re-enable the apps.
