Updating System Packages
Hello community!
I was wondering if it is recommended to update system packages using the command line instead of the web-ui (cockpit).
  • Using the Software Center, does this update all the packages that pertains to NethServer only or is it the equivalent to running yum update?
  • If I wanted to update using the command line, what is the proper way of updating the system packages?
Thanks in advance.
quite similar
any yum valid command, ns7 is a centos7 clone : yum update
Thank you. I wasn’t sure if yum would do or if there was a “nethserver way” to update from the commandline.
