what means this…: Deep Packet Inspection (DPI) module is not available
Restart the system and select a Linux kernel with DPI module support
Which kernel version is in use?
Check if you have the same problem as described here:
System version
NethServer release 7.5.1804 (final)
Kernel release
3.10.0-693.21.1.el7.x86_64
The same problem
Latest kernel is 3.10.0-862.3.2.el7.x86_64, but the updates could be blocked by another package. If yum update throws “Error unpacking rpm package python-backports-ssl_match_hostname” follow the instructions pointed on the other solved topic.
I make yum update but responde No packages marked for update
yum makecache
yum update
or if it does not work, clear the cache and try again.
The solution to the post is partial, only solves the problem with the update of the python-backports-ssl_match_hostname package. The problem with the DPI module has not been solved. The installed kernel is not compatible and yum has no kernel updates.
There must be some settings that create the kernel update problem but I can not find it.
Do you have subscription? Maybe the update is delayed due to that.
No! I don’t have a subscription!
If I look for the installed kernels I find the compatible version:
# rpm -qa kernel
kernel-3.10.0-693.11.6.el7.x86_64
kernel-3.10.0-693.11.1.el7.x86_64
kernel-3.10.0-693.17.1.el7.x86_64
kernel-3.10.0-862.3.2.el7.x86_64
kernel-3.10.0-693.21.1.el7.x86_64
I think it’s tied to a grub configuration but I’m not able to change it
@pasing, Did you reboot the server in order to load the new kernel?
Strange, I restarted it a few times only now it was successful.
Thanks for your patience and support, @dnutan!
