Update nextcloud and problem config
Ns8
Hi i have upgrade new version of app nextclod . in the summary information i read this :slight_smile:
The database lacks some indexes. Because adding indexes on large tables can take some time, they have not been added automatically. By running "occ db:add-missing-indices", missing indices can be added manually while the instance is running. Once the indices have been added, the queries to such tables are usually faster.
    Missing index "schedulobj?lastmodified?idx" in the table "oc-schedulingobjects".
i would like to execute this command from podman . Thanks
Here it is
Rebuilding the index is not a problem it’s a manual upgrade and optimization step. In many cases it is not needed.
A post was merged into an existing topic: Configure Nextcloud phone app
Hello David, I list another configuration about nextcloud where in my particular configuration with pfsense. , haproxy and nextcloud I unfortunately have something that is missing… On the netgate forum, a user told me to overwrite the apache form (as he uses it), to make the nexcloud server work properly. Below the apache code. But I understand that nextcloud uses the proxy or creed ngix. How can I do that?
 <IfModule mod_rewrite.c>
   RewriteEngine on
   RewriteRule ^/\.well-known/host-meta /public.php?service=host-meta [QSA,L]
   RewriteRule ^/\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L]
   RewriteRule ^/\.well-known/carddav /remote.php/dav [R=301,L]
   RewriteRule ^/\.well-known/caldav /remote.php/dav [R=301,L]
   RewriteRule ^/\.well-known/webfinger /index.php/.well-known/webfinger [R=301,L]
   RewriteRule ^/\.well-known/nodeinfo /index.php/.well-known/nodeinfo [R=301,L]
 </IfModule>
