I just (forcibly) pushed my v49 branch here: https://github.com/DavidePrincipi/ns-samba/tree/v49
Compare with current master https://github.com/NethServer/ns-samba/compare/master...DavidePrincipi:v49
I force push all the time on the wip-branches ![]()
I see there are more “BuildRequires” in your branch: are they really needed for ARM builds? Should I try to merge them in x86_64 or to add some %ifdef?
As said I did not really give it much thought, first time it did not build due to missing requirments.
then i’d just “pasted” this in:
The change has been moved up to… now! Travis builds now upload to 7.7.1908.
Which version of rspamd are targeting for 7.7 ?
cc/ @stephdl
I hope 1.9.4-3, we are waiting 2.0, but I do not think we will have it
Trying to upgrade to 7.7 1908 but I am not having luck with getting my server to upgrade
We are working on it, the release is not ready.
If you want to test it (without any support):
yum update --enablerepo=nethserver-testing nethserver-subscription
signal-event software-repos-upgrade
first test on a almost clean (only nethserver-dante installed) 7.6 VM
it seems all OK, i have only two error/information, both seems that can be ignored
Maybe your CPU is still Spectre/Meltdown vulnerable?
We have rc1 now Release candidate: ISO 7.7.1908 rc1
