Unistalling owncloud
On NS6 i have removed the owncloud package from the software center…but it is still accesible at https:///owncloud/ …What should I do to uninstall it completely?
Also remove the owncloude core rpm:
 yum remove owncloud
I suggest you also:
yum remove owncloud nethserver-owncloud
rm -rf /var/www/html/owncloud
mysql -e "drop database owncloud;"
Beware, that’s assuming you don’t wanna keep any owncloud configuration or user data under that path.
Yes, it will totally remove owncloud stuff.
