Ns8 has the ability of migrating modules between different Server/Nodes.
In some instances, each of the other node might have their own public ip address.
WHen i have a Master node, with publix ip 1.1.1.1
and i have a domainA pointed to1.1.1.1
if i add a second Node and the second server has ip 2.2.2.2
When a module migration/cloning of the module to the second Node with ip 2.2.2.2
Do i also need to adjust the SN records of the said Module to point to the second node ip, or so long as they are all pointed to node 1 they will work.
Does this scenraio apply to Node 1(master) alone, or the hostname can be pointed to any node in the cluster, and it will still work.
