I’m trying to migrate to a machine that is installed on Proxmox with Debian 12.
When running the command echo ‘{“action”:“login”,“Host”:“FQDN”,“User”:“Administrator”,“Password”:“*********”,“TLSVerify”:“disabled”}’ | /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-ns8-migration/connection/update | jq
The node log says
ns8-join: HTTP Error 401: Unauthorized.
The logs say [AUTH] redis authentication failed for user Administrator: WRONGPASS invalid username-password pair or user is disabled
And the log for traefik
2024-11-06T11:04:31+01:00 [1:traefik1:traefik] 192.168.0.1 - - [06/Nov/2024:10:04:31 +0000] “POST /cluster-admin/api/login HTTP/1.1” 401 67 “-” “-” 835 “ApiServer-https@file” “http://127.0.0.1:9311” 51ms
I’ve checked everything and credentials are correct and the account is active. I created a different user and it gives the same error message.
To begin with I just want to inform you that I gave up and uninstalled the installation and then ran the installation again including to download the latest files. My NS7 is also completely updated.
No down to business.
I can ping between the servers using their hostnames but not on the ns8/wg0 IP.
When I ran the initial setup it ran fine until i got a timeout and after that can’t I connect to it again.
On NS7 it looks as I would except
ns8: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.5.4.2/32 scope global ns8
valid_lft forever preferred_lft forever
inet6 fe80::83e9:955f:cdfb:afd1/64 scope link flags 800
On NS8 I get this output.
wg0: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.5.4.1/32 scope global wg0
So far so good as far as I can see.
When I run redis-cli keys node/*/vpn I get this response.
I checked the configuration and it has the same IP on both sides, redis has two records but from what I understand that shouldn’t cause any problems.
It worked when I tried again to ping ns8 → wg0 , maybe I tried in the wrong direction earlier.
When I reload the migration page it throws this in the NS7 logs. I’ve reversed the order so read it from top to bottom.
10:38 root : TTY=unknown ; PWD=/run/user/0 ; USER=root ; COMMAND=/usr/libexec/nethserver/api/nethserver-ns8-migration/migration/read sudo
10:38 pam_unix(sudo:session): session opened for user root by root(uid=0) sudo
10:38 Traceback (most recent call last): cockpit-bridge
10:38 File “/usr/lib64/python3.6/urllib/request.py”, line 1349, in do_open cockpit-bridge
10:38 encode_chunked=req.has_header(‘Transfer-encoding’)) cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 1254, in request cockpit-bridge
10:38self._send_request(method, url, body, headers, encode_chunked) cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 1300, in _send_request cockpit-bridge
10:38 self.endheaders(body, encode_chunked=encode_chunked) cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 1249, in endheaders cockpit-bridge
10:38 self._send_output(message_body, encode_chunked=encode_chunked) cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 1036, in _send_output cockpit-bridge
10:38 self.send(msg) cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 974, in send cockpit-bridge
10:38 self.connect() cockpit-bridge
10:38 File “/usr/lib64/python3.6/http/client.py”, line 946, in connect cockpit-bridge
10:38 (self.host,self.port), self.timeout, self.source_address) cockpit-bridge
10:38 File “/usr/lib64/python3.6/socket.py”, line 724, in create_connection cockpit-bridge
10:38 raise err cockpit-bridge
10:38 File “/usr/lib64/python3.6/socket.py”, line 713, in create_connection cockpit-bridge
10:38 sock.connect(sa) cockpit-bridge
10:38 socket.timeout: timed out cockpit-bridge
10:38 During handling of the above exception, another exception occurred: cockpit-bridge
10:38 File “/usr/sbin/ns8-action”, line 104, in cockpit-bridge
10:38 resp = request.urlopen(req, timeout = 20) cockpit-bridge
10:38 File “/usr/lib64/python3.6/urllib/request.py”, line 223, in urlopen cockpit-bridge
10:38 return opener.open(url, data, timeout) cockpit-bridge
I got and idea from your response, the problem was with the firewall on Debian. I’ve shut it down temporarily now and can see the migration options.
Now I need to check everything at least three times to avoid running into problems after the migration.
