Unable to open documents using OnlyOffice
NethServer Version: NethServer 7.9.2009
Module: your_module
how to fix this isu. this isu faceing today when completed update.
plz help me anyone
@sazzad, welcome to the Nethserver community. In order to help you, we’re going to need a great deal more information from you. Let’s start with the the most basic: What is the “this isu” (presumably “issue”) you refer to?
Your description of the problem is very confused. Can’t you be a little more precise?
only office not working
error: ONLYOFFICE cannot be reached. Please contact admin
Please take a screenshot of the Onlyoffice administration page in Nextcloud and post it here. What error messages does the event log show?
Which version of Onlyoffice are you using? Later than 7.1.1 does not work at this time.
What happens when you press the Save button?
Please remove the address for internal requests, it’s not needed.
Can you reach https://aplus.cloud.server:8082 from the public? Depending on your network you may need a port forwarding…
This version
https://aplus.cloud.server:8082 its only hostname. not public domain. i am using Port forwarding.
I recommend to use a public domain and a valid certificate like letsencrypt for production use.
If that’s not possible you could setup a self-signed cert and host, see also onlyoffice [NethServer Wiki]
ohh! thanks …
But any options without public domain
It was possible without public domain and valid certificate but I didn’t test with recent versions:
i am tried onlyoffice [NethServer Wiki] doing this. ageing :sob:flied
you have any others apss solutions. only office like .
:cry: :cry: try both . doesn’t solve isu.
Collabora requires a public domain and a valid certificate.
