@harry What did you try to solve it and what is your configuration?
EPEL has released ufdbGuard and we have nethserver-squidguard ready to be tested.
Instruction for the braves:
On an existing system I got after running the above command and then yum update
Transaction check error:
file /etc/sysconfig/ufdbguard from install of ufdbGuard-1.34.6-2.el7.x86_64 conflicts with file from package ufdbGuard-1.34.5-2.el7.x86_64
Then tried
yum remove ufdbGuard
It also removed
After removal reun
yum --enablerepo=epel-testing,nethserver-testing install nethserver-squidguard
and then
yum update
All appears to work
Thanks
All the updated packages have been released: you could update from the server-manager or with yum update.
@filippo_carletti I did the update today? Have the patches only just been released since?
The failed one below looks like it is calling for the right packages but failed. Should we just wait and it will sort out?
The following updates will be applied on
Package Arch Version Repository Size
Updating:
certbot noarch 1.7.0-1.el7 epel 45 k
python2-acme noarch 1.7.0-1.el7 epel 82 k
python2-certbot noarch 1.7.0-1.el7 epel 376 k
ufdbGuard x86_64 1.34.6-2.el7 epel 517 k
Transaction Summary
Upgrade 4 Packages
Updates failed to install with the following error message:
Could not run transaction.
But the system where I had manually worked around the issue is back to automatic updates
Updating:
nethserver-fail2ban noarch 1.4.2-1.ns7 nethserver-updates 1.1 M
nethserver-mail-common noarch 2.17.2-1.ns7 nethserver-updates 1.5 M
nethserver-mail-disclaimer noarch 2.17.2-1.ns7 nethserver-updates 43 k
nethserver-mail-filter noarch 2.17.2-1.ns7 nethserver-updates 90 k
nethserver-mail-server noarch 2.17.2-1.ns7 nethserver-updates 129 k
nethserver-mail-smarthost noarch 2.17.2-1.ns7 nethserver-updates 56 k
nethserver-nextcloud noarch 1.13.0-1.ns7 nethserver-updates 89 M
nethserver-squid noarch 1.10.12-1.ns7 nethserver-updates 1.3 M
nethserver-squidguard noarch 2.0.2-1.ns7 nethserver-updates 68 k
Transaction Summary
Upgrade 9 Packages
The updates were successfully applied
Does it help if you move away the conflicting /etc/sysconfig/ufdbguard file?
You may try to remove nethserver-squidguard and ufdbguard and install again.
@mrmarkuz That is actually what we did and it worked
It also removed
After removal reun
For my server this issue is not done still. After clean-all cache (with enabled testing repos), the error remains on update (with enabled testing repos):
Determining fastest mirrors
epel/x86_64/metalink | 18 kB 00:00:00
epel-testing/x86_64/metalink | 11 kB 00:00:00
* epel: ftp.plusline.net
* epel-testing: ftp.plusline.net
ce-base/7/x86_64/signature | 811 B 00:00:00
ce-base/7/x86_64/signature | 3.6 kB 00:00:00 !!!
ce-extras/7/x86_64/signature | 811 B 00:00:00
ce-extras/7/x86_64/signature | 3.4 kB 00:00:00 !!!
ce-sclo-rh | 3.0 kB 00:00:00
ce-sclo-sclo | 2.9 kB 00:00:00
ce-updates/7/x86_64/signature | 811 B 00:00:00
ce-updates/7/x86_64/signature | 3.4 kB 00:00:00 !!!
epel | 4.7 kB 00:00:00
epel-testing | 4.7 kB 00:00:00
nethforge/7/x86_64/signature | 836 B 00:00:00
nethforge/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethserver-base/7/x86_64/signature | 836 B 00:00:00
nethserver-base/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethserver-testing/7/x86_64/signature | 836 B 00:00:00
nethserver-testing/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethserver-updates/7/x86_64/signature | 836 B 00:00:00
nethserver-updates/7/x86_64/signature | 3.6 kB 00:00:00 !!!
stephdl | 2.9 kB 00:00:00
(1/18): ce-base/7/x86_64/group_gz | 166 kB 00:00:01
(2/18): ce-extras/7/x86_64/primary_db | 215 kB 00:00:01
(3/18): ce-sclo-sclo/7/x86_64/primary_db | 308 kB 00:00:01
(4/18): epel/x86_64/updateinfo | 1.0 MB 00:00:00
(5/18): epel/x86_64/primary_db | 6.9 MB 00:00:00
(6/18): epel-testing/x86_64/group_gz | 95 kB 00:00:00
(7/18): epel-testing/x86_64/updateinfo | 38 kB 00:00:00
(8/18): epel-testing/x86_64/primary_db | 300 kB 00:00:00
(9/18): nethforge/7/x86_64/primary_db | 76 kB 00:00:00
(10/18): nethserver-base/7/x86_64/primary_db | 331 kB 00:00:00
(11/18): nethserver-testing/7/x86_64/primary_db | 5.0 kB 00:00:00
(12/18): nethserver-updates/7/x86_64/group_gz | 20 kB 00:00:00
(13/18): nethserver-updates/7/x86_64/primary_db | 660 kB 00:00:00
(14/18): stephdl/7/primary_db | 317 kB 00:00:00
(15/18): ce-sclo-rh/7/x86_64/primary_db | 3.9 MB 00:00:07
(16/18): ce-base/7/x86_64/primary_db | 6.0 MB 00:00:08
(17/18): epel/x86_64/group_gz | 95 kB 00:00:07
(18/18): ce-updates/7/x86_64/primary_db | 7.4 MB 00:00:08
Resolving Dependencies
--> Running transaction check
---> Package ufdbGuard.x86_64 0:1.33.7-CentOS7 will be updated
---> Package ufdbGuard.x86_64 0:1.35.3-1.el7 will be an update
Dependencies Resolved
Updating:
ufdbGuard x86_64 1.35.3-1.el7 epel-testing 519 k
Transaction Summary
Upgrade 1 Package
Total download size: 519 k
Is this ok [y/d/N]: y
Downloading packages:
epel-testing/x86_64/prestodelta | 75 B 00:00:00
ufdbGuard-1.35.3-1.el7.x86_64.rpm | 519 kB 00:00:00
Running transaction test
file /var/log/ufdbguard from install of ufdbGuard-1.35.3-1.el7.x86_64 conflicts with file from package nethserver-squidguard-1.9.1-1.ns7.noarch
Error Summary
Which Nethserver version do you have?
I thought I was up-to-date as did update and did not see any new version notification. But found “NethServer release 7.6.1810 (final)”. So I need some upgrading.
Uninstall ufdbguard
update the system to 7.8.2003
yum clean all
yum update
and reinstall ufdbguard with:
yum install --enablerepo=nethserver-testing,epel-testing nethserver-squidguard ufdbGuard
This should work
For the record, another approach without testing repository:
Install nethserver-subscription package to enable upgrade option in admin web ui.
Start upgrade to 7.7 in the ui. It fails with the mentioned conflict.
Start upgrade on console with excluding ufdbGuard. This succeeds.
Start upgrade from 7.7 to 7.8 from the admin web ui again. This time this succeeds, too, the conflict is no longer present during this upgrade.
