Hallo,
today I figured out that ufdbguard is blocking ssh access to a server (outsite of my lan) with a self sinǵned certificate.
Can I switch off ssh blocking for a special domain / IP ?
with warm regards from Leipzig
Denis
The documentation of ufdbguard is a little bit poor in that point.
mrmarkuz
(Markus Neuberger)
2
Hi Denis,
are you sure ufdbguard is blocking?
You may bypass the proxy so ufdbguard can’t check:
http://docs.nethserver.org/en/v7/web_proxy.html#bypass
Hallo,
yesterday I had much time to investigate the problem.
The ssl tunnel was blocked for one destination only.
So I checked all possibilities
- fail2ban
- firewall rules
- firewall dynamic blocking
And ola: my destination was blocked by shorewall. The reason why I could not discover …
Now all is working fine.
