it was a NAT during the installation.
After I put the correct network setting in the virtual box
With the browser,
I succesfiull connect and made the wizard configuration with the bridged adapter
With the browser,
Yes but in âNS you have NATâ as @filippo_carletti said .
Try to reinstall NS with âbridgedâ from beginning.
If iâm not wrong nat will show port 980 on your machine as youâre using
nat, i prefer bridge to avoid that kind of problems.
Okay,
I will resinstall all
On linux you must install bridge-utils if you want to use a bridgeâŠon apple i donât know.
It seem that Mac OS X able to bridge the adapter without nothing more to install.
But I was not able to create a vlan as @GG_jr show in the screenshot, only o bridged adapter.
wlan0 is my laptop wireless adapter. If you have wired connection, you will see eth0.
Itâs OK how you have set your VM.
Why reinstall? just change de nat to bridge and the ips.
I had already change the setti gâŠ
But look at my screenshot
The old one
Try to reinstall from scratch, using the informations that you got from here.
It take only 15 minutes and sure will works.
If you want to use the new VM as Firewall, after first login, you must add and set a new Green interface; after that, you must change eth0 from Green to Red (you cannot change from Green to Red before add a new Green interface).
Attention: you must set additional interfaces in VM VirtualBox if you want to build a Virtual Network. In VM VirtualBox, the additional interfaces will be attached to Internal Network. These interfaces will be used in NS VM for Orange, Blue, Green.
After a reinstall from scratch, all is perfectly running.
Thank you all
Now youâre an expert, you MUST make a video for install NethServer on VirtualBox
Iâm only a Rising Virtualbox User
Iâm more a âphotographâ with print screen than a âcineastâ making filmâŠ
I have to find an âHowto make a film capturing a screenâ and " howto become a youtuber"
Using a screenrecorder is easier than⊠posting here⊠
On OSX you can just use the default screen recorder http://osxdaily.com/2010/11/16/screen-recorder-mac/
On Linux (ubuntu in my case) you can use RecordMydesktop or simple screenrecorder.
Try it, itâs actually fun to do.
I will be difficult to pull out now
Even if the real virtualbox experts are @ctek, @GG_jr and @stephdl
I will try to play with
http://wiki.contribs.org/Virtual_SME_Server
This kind of page is missingâŠfollowing the different type of virtualisation you might have settings or strategies different.
OhhhhâŠA wiki.
Finally Quick Time Player do it natively on the Mac since OS X LionâŠ
Let me a little time to see how it work.
