Trying to mount a shared folder - permission denied
I’m trying to mount a shared folder from my nethserver on my Kubuntu system eith the following command:
sudo mount -t cifs -v -o username=testuser //ip-to-myserver/testshare /media/mountfolder
after inserting hte required password a get the message
mount error(13): Permission denied
When I connect via the KDE Filemanager Dolphin, everything works.
Any ideas?
NethServer Version: 7.6.1810
Module: your_module
I’ve found a way to connect:
sudo mount -t cifs -v -o username=DOMAIN\testuser //ip-to-my-server/testshare /media/mountfolder
But this works if I set the guest permissions to read & write only. When I restrict the access to the my connecting user, then it’s not possible to connect?
I found out that I have to mount the shared folder with some permissions set, otherwise I’m not able to create files and folders.
sudo /bin/mount -t cifs /ip-to-my-server/testshare /media/mountfolder -o user=local\testuser,uid=1000,gid=1000,file_mode=0660,dir_mode=0770,nounix
Is this the proper way to connect to a shared folder on nethserver?
Same happened with me… Thanks
You can mount it with something like:
 mount -o username=giacomo //192.168.1.1/iba1 /media/mountfolder
Just tested, it works. Instead of using the IP address it should be better to use the server name.
Did you forgot the option
-t cifs
or does it work without it?
It works anyway. :slight_smile:
