Try out Nethserver 7 beta1
Someone else got this error when installing the packages?
Transaction check error:
file /etc/e-smith/db/configuration/defaults/spamassassin/access from install of nethserver-p3scan-1.1.0-1.ns7.noarch conflicts with file from package nethserver-spamd-1.0.0-1.ns7.noarch
file /etc/e-smith/templates/etc/mail/spamassassin/bwlist.cf/10wbl from install of nethserver-p3scan-1.1.0-1.ns7.noarch conflicts with file from package nethserver-spamd-1.0.0-1.ns7.noarch
The first reset failed, so for giggles I reset it again and that was successful, I have been able to create users and groups and this and that.
log from failure to reset…
Aug 30 14:34:23 server7c kernel: br0: port 2(vb-nsdc) entered forwarding state Aug 30 14:36:03 server7c systemd: Starting Cleanup of Temporary Directories... Aug 30 14:36:03 server7c systemd: Started Cleanup of Temporary Directories. Aug 30 14:46:12 server7c dhclient[834]: DHCPREQUEST on br0 to 192.168.124.2 port 67 (xid=0x1c838f10) Aug 30 14:46:12 server7c dhclient[834]: DHCPACK from 192.168.124.2 (xid=0x1c838f10) Aug 30 14:46:14 server7c dhclient[834]: bound to 192.168.124.227 -- renewal in 1348 seconds. Aug 30 14:46:32 server7c smbd[2399]: [2016/08/30 14:46:32.812281, 0] ../source3/printing/print_cups.c:151(cups_connect) Aug 30 14:46:32 server7c smbd[2399]: Unable to connect to CUPS server localhost:631 - Transport endpoint is not connected Aug 30 14:46:32 server7c smbd[1338]: [2016/08/30 14:46:32.812976, 0] ../source3/printing/print_cups.c:529(cups_async_callback) Aug 30 14:46:32 server7c smbd[1338]: failed to retrieve printer list: NT_STATUS_UNSUCCESSFUL Aug 30 14:54:09 server7c esmith::event[1975]: [ERROR] could not connect to Samba Domain Controller Aug 30 14:54:09 server7c esmith::event[1975]: Action: /etc/e-smith/events/nethserver-dc-save/S95nethserver-dc-waitstart FAILED: 1 [1201.016324] Aug 30 14:54:09 server7c /sbin/e-smith/db[2609]: /var/lib/nethserver/db/configuration: OLD sssd=service|AdDns|192.168.124.228|LdapURI||Provider|none|status|disabled Aug 30 14:54:09 server7c /sbin/e-smith/db[2609]: /var/lib/nethserver/db/configuration: NEW sssd=service|AdDns|192.168.124.228|LdapURI||Provider|ad|status|disabled Aug 30 14:54:09 server7c dbus[589]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' Aug 30 14:54:09 server7c dbus-daemon: dbus[589]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' Aug 30 14:54:09 server7c systemd: Starting Time & Date Service... Aug 30 14:54:09 server7c dbus[589]: [system] Successfully activated service 'org.freedesktop.timedate1' Aug 30 14:54:09 server7c dbus-daemon: dbus[589]: [system] Successfully activated service 'org.freedesktop.timedate1' Aug 30 14:54:09 server7c systemd: Started Time & Date Service. Aug 30 14:54:09 server7c /sbin/e-smith/db[2609]: /var/lib/nethserver/db/configuration: OLD sssd=service|AdDns|192.168.124.228|LdapURI||Provider|ad|status|disabled Aug 30 14:54:09 server7c /sbin/e-smith/db[2609]: /var/lib/nethserver/db/configuration: NEW sssd=service|AdDns|192.168.124.228|LdapURI||Provider|ad|status|enabled Aug 30 14:54:10 server7c dnsmasq[1998]: exiting on receipt of SIGTERM Aug 30 14:54:10 server7c systemd: Stopping DNS caching server.... Aug 30 14:54:10 server7c systemd: Started DNS caching server.. Aug 30 14:54:10 server7c systemd: Starting DNS caching server.... Aug 30 14:54:10 server7c dnsmasq[2614]: started, version 2.66 cachesize 4000 Aug 30 14:54:10 server7c dnsmasq[2614]: compile time options: IPv6 GNU-getopt DBus no-i18n IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth Aug 30 14:54:10 server7c dnsmasq-tftp[2614]: TFTP root is /var/lib/tftpboot Aug 30 14:54:10 server7c dnsmasq[2614]: using nameserver 192.168.124.228#53 for domain ad.test.lab.local Aug 30 14:54:10 server7c dnsmasq[2614]: using nameserver 192.168.124.2#53 Aug 30 14:54:10 server7c dnsmasq[2614]: read /etc/hosts - 2 addresses Aug 30 14:54:10 server7c dbus[589]: [system] Activating service name='org.freedesktop.realmd' (using servicehelper) Aug 30 14:54:10 server7c dbus-daemon: dbus[589]: [system] Activating service name='org.freedesktop.realmd' (using servicehelper) Aug 30 14:54:10 server7c dbus[589]: [system] Successfully activated service 'org.freedesktop.realmd' Aug 30 14:54:10 server7c dbus-daemon: dbus[589]: [system] Successfully activated service 'org.freedesktop.realmd' Aug 30 14:54:10 server7c dbus[589]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' Aug 30 14:54:10 server7c dbus-daemon: dbus[589]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' Aug 30 14:54:10 server7c systemd: Starting Authorization Manager... Aug 30 14:54:10 server7c polkitd[2625]: Started polkitd version 0.112 Aug 30 14:54:10 server7c dbus-daemon: dbus[589]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Aug 30 14:54:10 server7c dbus[589]: [system] Successfully activated service 'org.freedesktop.PolicyKit1' Aug 30 14:54:10 server7c systemd: Started Authorization Manager. Aug 30 14:54:10 server7c realmd: * Resolving: _ldap._tcp.ad.test.lab.local Aug 30 14:54:26 server7c realmd: ! Discovery timed out after 15 seconds Aug 30 14:54:26 server7c esmith::event[1975]: realm: No such realm found Aug 30 14:54:26 server7c esmith::event[1975]: [ERROR] DC join failed Aug 30 14:54:26 server7c esmith::event[1975]: Action: /etc/e-smith/events/nethserver-dc-save/S96nethserver-dc-join FAILED: 1 [16.561848] Aug 30 14:54:30 server7c esmith::event[1975]: Minimum password age changed! Aug 30 14:54:30 server7c esmith::event[1975]: Maximum password age changed! Aug 30 14:54:30 server7c esmith::event[1975]: All changes applied successfully! Aug 30 14:54:31 server7c esmith::event[1975]: Action: /etc/e-smith/events/nethserver-dc-save/S97nethserver-dc-password-policy SUCCESS [5.523482] Aug 30 14:54:31 server7c esmith::event[1975]: Event: nethserver-dc-save FAILED
ads_connect: No logon servers ads_connect: No logon servers Didn't find the ldap server! ads_connect: No logon servers Join to domain is not valid: No logon servers
My bad, I forgot to release the updated nethserver-p3scan rpm.
I just pushed the new release to updates (nethserver-p3scan-1.1.1-1.ns7.noarch.rpm).
In the meanwhile, you can use the package from testing which is already fixed since time ago ( Replace Fetchmail with getmail · Issue #5021 · NethServer/dev · GitHub ).
Anyway, great catch! :clap:
That action waits for the Samba Active Directory DNS service to respond.
It seems nsdc didn’t come up. Perhaps the lines from journalctl -u nsdc before Aug 30 14:54:09 provide some clues.
too late I guess…
[root@server7c ~]# journalctl -u nsdc -- Logs begin at Tue 2016-08-30 15:09:59 MST, end at Wed 2016-08-31 09:41:57 MST. --
Beta2 ISO is available! Update existing beta1 installations from the Software Center
