What installation did you tried?
Using the interactive install, you must choose it from the web interface.
If you use the unattended one, keyboard is set to US and timezone to UTC (this behavior has not changed from 6.x).
[root@server89 ~]# yum grouplist -v
Loading "changelog" plugin
Loading "fastestmirror" plugin
Loading "nethserver_events" plugin
Config time: 0.158
Yum version: 3.4.3
Setting up Package Sacks
* base: mirror.san.fastserv.com
* epel: dl.fedoraproject.org
* extras: mirror.spro.net
* nethserver-base: nethserver.de-labrusse.fr
* nethserver-updates: nethserver.de-labrusse.fr
* updates: mirror.hmc.edu
pkgsack time: 0.402
group time: 0.446
Installed Groups:
Backup (nethserver-backup)
Available Groups:
Bandwidth monitor (nethserver-bandwidth-monitor)
Basic firewall (nethserver-firewall-base)
DNS and DHCP server (nethserver-dns-dhcp)
Dutch language (nethserver-l10n-nl)
Email (nethserver-mail)
FTP server (nethserver-ftp)
Fax server (nethserver-fax-server)
File server (nethserver-file-server)
French language (nethserver-l10n-fr)
German language (nethserver-l10n-de)
Greek language (nethserver-l10n-el)
Hungarian language (nethserver-l10n-hu)
Instant messaging (nethserver-messaging)
Intrusion Prevention System (nethserver-ips)
Italian language (nethserver-l10n-it)
Monitoring and inventorying (nethserver-monitoring)
MySQL server (nethserver-mysql)
NethForge (nethserver-nethforge)
POP3 connector (nethserver-pop3connector)
POP3 proxy (nethserver-p3scan)
Portuguese language (nethserver-l10n-pt)
Print server (nethserver-printers)
Russian language (nethserver-l10n-ru)
SMTP proxy (nethserver-smtp-proxy)
SNMP server (nethserver-net-snmp)
SOGo groupware (nethserver-groupware)
Spanish language (nethserver-l10n-es)
Statistics (nethserver-statistics)
Turkish language (nethserver-l10n-tr)
UPS support (nethserver-nut)
VPN (nethserver-vpn)
Virtual machines manager (nethserver-webvirtmgr)
Web filter (nethserver-web-filter)
Web proxy (nethserver-web-proxy)
Web server (nethserver-web)
Web-based fax client (nethserver-faxweb2)
WebTop groupware (nethserver-webtop-groupware)
ownCloud (nethserver-owncloud)
Done
Weird, for example ownCloud is available to install though it is installed. I know I ran an update on this after installing those modules, these were installed through the software center.
I just installed file server in the fresh base install and post reboot it shows backup and file server as installed so all is well in the software center now.
alefattorini
(Alessio Fattorini)
Split this topic
93
Generation 2 machines have a much thinner Hardwarelayer. Because of this, they removed the support of many legacy devices. You can read more details here: https://technet.microsoft.com/en-us/library/dn282285.aspx
Or more technical:
Is Nethserver 7.x based on CentOS7? If yes, regarding the MS-Docs it should work, if UEFI is activated and SecureBoot disabled.
G’day first post, so anything is good.
I guess I’m your beta Nethserver tester too than;)
running:
OS: CentOS Linux release 7.2.1511 (Core)
CPE OS Name: cpe:/o:centos:centos:7
Kernel: Linux 3.10.0-327.10.1.el7.x86_64
Architecture: x86-64
will be testing: nethserver-7.2.1511-alpha2-x86_64 too(next few Days)
kind foreseeing same result as tonight’s runs;
