Have been interested in looking at the Monitoring and Inventorying module, but it won’t install. Software Center repeatedly says to clean yum caches, but won’t work. Trying manually with yum (even after yum clean all) in ssh yields these errors:
Error: Package: winexe-1.1-1.git.0.9d83c1e.el6.x86_64 (nethserver-base)
Requires: libcli-ldap.so(SAMBA_4.0.0RC4)(64bit)
Available: samba4-libs-4.0.0-66.el6_6.rc4.x86_64 (centos-base)
Available: samba4-libs-4.0.0-67.el6_7.rc4.x86_64 (centos-updates)
Available: samba4-libs-4.0.0-68.el6_7.rc4.x86_64 (centos-updates)
Installing: samba4-libs-4.2.10-6.el6_7.x86_64 (centos-updates)
Not found
Requires: libdcerpc-samba.so()(64bit)
Not found
Requires: liberrors.so()(64bit)
Not found
Requires: libdcerpc-samba.so(SAMBA_4.0.0RC4)(64bit)
Not found
Requires: liberrors.so(SAMBA_4.0.0RC4)(64bit)
Not found
Requires: libcli-ldap.so()(64bit)
Not found
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
