Hello! Anyone using traefik in nethserver? Can someone made module for nethserver?
Please search for past discussions about it
https://community.nethserver.org/search?context=topic&context_id=11140&q=traefik&skip_context=true
We evaluated it for Docker integration, but in the end we enhanced the existing Reverse proxy module, so there aren’t plans for it at the moment.
And there are no plans to expand the existing reverse proxy? For example, balancing between multiple servers, cache…?
Not here, but if you share the same need with others they can chime in!
