Traefik certificate upload does not work anymore
NethServer Version: core 3.6.4
Module: traefik 3.0.2
I have the problem, that the certificate upload does not work anymore.
I try to upload a certificate which I created with win-acme, what worked for a long time without problems, but i get the error:
error 20 at 0 depth lookup: unable to get local issuer certificate
error uploaded_cert: verification failed
Does anyone have an idea?
Thanks
Regards
I got it.
From win-acme I get 4 files:
chain.pem ,
chain-only.pem ,
crt.pem ,
key.pem .
In the past I used crt.pem and key.pem and it worked.
Now I must use chain.pem and key.pem and it work again.
Regards
