NethServer Version: latest
Tried to install Traccar. Traccar (www.traccar.org) is a modern open source GPS tracking Platform.
### HowTo install Traccar on Nethserver 7 ###
Traccar (www.traccar.org) is a modern GPS tracking Platform.
# wget the software-archive
wget -c https://github.com/traccar/traccar/releases/download/v4.5/traccar-linux-64-4.5.zip
# Install unzip and extract the archive
yum -y install unzip && unzip traccar-linux-64-4.5.zip
# run traccar.run
./traccar.run
# Now a symlink should be created
# /etc/systemd/system/multi-user.target.wants/traccar.service to /etc/systemd/system/traccar.service.
# Remove the archive
rm -rf traccar-linux-64-4.5.zip
# Open and adjust the firewall
config set traccar service status enabled TCPPort 8082 access green
signal-event firewall-adjust
# Reboot your server
reboot
# Login
http://nethserverip:8082/
user: admin
pass: admin
I can access the traccar serverpage (http://nethserverip:8082/) but the client (android) cannot connect… Is someone using Traccar on Nethserver?
