fausp
(fpausp)
21
Thats bad luck, but not a big problem…
fausp
(fpausp)
22
SSL-Cert creation and import on Win10 PC went well but howto use it / import it on Nethserver?
fausp
(fpausp)
23
I think the Alternative names are now implemented?
flatspin
(Ralf Jeckel)
24
Just copy the cert to /etc/pki/tls/certs/ and the key to /etc/pki/tls/private/ and it will appear here:
Yes. You can also give here the IP-adress to have a valid cert if you reach the server through it’s IP.
