TLS/Cyphers question
Hi all,
SSL labs gives me an A which is good, but there are weak cyphers still lingering in Nethserver…
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030) ECDH secp256r1 (eq. 3072 bits RSA) FS 256
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028) ECDH secp256r1 (eq. 3072 bits RSA) FS WEAK 256
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f) ECDH secp256r1 (eq. 3072 bits RSA) FS 128
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027) ECDH secp256r1 (eq. 3072 bits RSA) FS WEAK 128
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (0x9f) DH 2048 bits FS 256
TLS_DHE_RSA_WITH_AES_256_CBC_SHA256 (0x6b) DH 2048 bits FS WEAK 256
TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (0x9e) DH 2048 bits FS 128
TLS_DHE_RSA_WITH_AES_128_CBC_SHA256 (0x67) DH 2048 bits FS WEAK 128
TLS_RSA_WITH_AES_256_GCM_SHA384 (0x9d) WEAK 256
TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d) WEAK 256
TLS_RSA_WITH_AES_128_GCM_SHA256 (0x9c) WEAK 128
TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c) WEAK 128
Is there a way to get rid of the weak cyphers?
Thanks in advance
GB
It should be possible to define the ciphers in /etc/httpd/conf.d/nethserver.conf, you may need a custom template.
Thanks for the reply…I’d need a bit of help here, please as I don’t want to mess things up…
thanks
GB
The following customization overrides the TLS policy setting for httpd.
Create the directory for the custom template fragment:
mkdir -p /etc/e-smith/templates-custom/etc/httpd/conf.d/nethserver.conf/
Create the fragment file /etc/e-smith/templates-custom/etc/httpd/conf.d/nethserver.conf/11tls_policy_custom with following content:
# custom cipher selection
SSLProtocol all -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLCipherSuite ALL:!RSA:!CAMELLIA:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!RC4:!SHA1:!SHA256:!SHA384
SSLHonorCipherOrder on
SSLCompression Off
Apply the configuration:
signal-event nethserver-httpd-update
Thanks for the help, I’d have messed up on my own… Appreciate the assistance and your time…
