NethServer Version: 7.8.2003 & 7.9.2009
Module: dovecot
A couple of users tried to activate the autoresponder from Thunderbird as usual when holidays comes …
It had worked fine until this summer. Now it seems not to works.
I suppose this is a TB problem (plug-in ManageSieve), but tried with the TB independent version (not very different from the plug-in),
It can’t authenticate.
Anyone have already seen this problem and found some workaround?
In the maillog I have:
Dec 23 18:28:01 posta dovecot: managesieve-login: Aborted login (auth failed, 1 attempts in 85 secs): user=, method=PLAIN, rip=192.168.2.135, lip=192.168.2.250, TLS, session=<MBZP/iS308PAqAKH>
Dec 23 18:28:12 posta rspamd[1332]: ; lua; bayes_expiry.lua:440: finished expiry step 14: 989 items checked, 241 significant (0 made persistent), 0 insignificant (0 ttls set), 0 common (0 discriminated), 748 infrequent (0 ttls set), 64 mean, 210 std
Dec 23 18:28:25 posta dovecot: managesieve-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=192.168.2.135, lip=192.168.2.250, TLS: SSL_read() failed: error:14094412:SSL routines:ssl3_read_bytes
:sslv3 alert bad certificate: SSL alert number 42, session=
Dec 23 18:28:34 posta dovecot: managesieve-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=192.168.2.135, lip=192.168.2.250, TLS: SSL_read() failed: error:14094412:SSL routines:ssl3_read_bytes:sslv3 alert bad certificate: SSL alert number 42, session=
