since a picture is worth a thousand words
If the Confidence field has some value, it can of course can be sorted.
Examples:
I couldn’t test the sorting on Status field, @andre8244 could you please take a look?
Thanks @JOduMonT, we are working on it right now: https://github.com/NethServer/dev/issues/6140
That was fast! The package is ready to be tested.
Attention, the package is published inside NS 7.8.
If you want to test in into a 7.7:
yum install http://packages.nethserver.org/nethserver/7.8.2003/testing/x86_64/Packages/nethserver-blacklist-1.0.2-1.1.g89a57ee.ns7.noarch.rpm
@JOduMonT would you give a try and report back?
On my side there are only unknown confidences so nothing to sort…status is working.
That shouldn’t be necessary as relevant services are restarted at installation/update. Tough a reboot is always good to see if something is still starting/working.
It doesn’t sort because all lists have Unknown confidence.
Thank you both for the tests!
