For some time now updates have failed. I have not worried about it too much since otherwise everything seems to be fine.
The result is the same whether I try ‘update all’ or individual updates. It goes through init > resolve RPM dependencies > download and then throws an error: check API for more info: system packages /update.
The log entry:
pkgactionTue Sep 03 2019 09:56:24 GMT-0700 (Pacific Daylight Time)
[YumTestTransactionError] Test Transaction Errors:
package glib2-2.56.1-4.el7_6.x86_64 is already installed
package iproute-4.11.0-14.el7_6.2.x86_64 is already installed
package openssl-libs-1:1.0.2k-16.el7_6.1.x86_64 is already installed
package gnutls-3.3.29-9.el7_6.x86_64 is already installed
package nethserver-subscription-3.4.1-1.ns7.noarch is already installed
package libsss_autofs-1.16.2-13.el7_6.8.x86_64 is already installed
package pango-1.42.4-2.el7_6.x86_64 is already installed
package libsss_nss_idmap-1.16.2-13.el7_6.8.x86_64 is already installed
package python2-future-0.16.0-15.20181019gitbee0f3b.el7.noarch is already installed
package nss-sysinit-3.36.0-7.1.el7_6.x86_64 is already installed
package python-zope-component-1:4.1.0-5.el7.noarch is already installed
package shadow-utils-2:4.1.5.1-25.el7_6.1.x86_64 is already installed
package duplicity-0.7.19-1.el7.x86_64 is already installed
package nethserver-dnsmasq-1.7.0-1.ns7.noarch is already installed
package python-2.7.5-80.el7_6.x86_64 is already installed
package mokutil-15-2.el7.centos.x86_64 is already installed
package nethserver-base-3.7.3-1.ns7.noarch is already installed
package rspamd-1.9.1-1.x86_64 is already installed
package freetype-2.8-12.el7_6.1.x86_64 is already installed
package libsss_idmap-1.16.2-13.el7_6.8.x86_64 is already installed
package rsync-3.1.2-6.el7_6.1.x86_64 is already installed
package nss-util-3.36.0-1.1.el7_6.x86_64 is already installed
package nss-pem-1.0.3-5.el7_6.1.x86_64 is already installed
package glibc-2.17-260.el7_6.6.x86_64 is already installed
package sope49-xml-4.9-20190311_2200.ns7.x86_64 is already installed
package python2-mock-1.0.1-10.el7.noarch is already installed
package libsss_certmap-1.16.2-13.el7_6.8.x86_64 is already installed
package libipa_hbac-1.16.2-13.el7_6.8.x86_64 is already installed
package krb5-libs-1.15.1-37.el7_6.x86_64 is already installed
package nss-3.36.0-7.1.el7_6.x86_64 is already installed
package openldap-2.4.44-21.el7_6.x86_64 is already installed
package sope49-gdl1-contentstore-4.0.7-1.ns7.x86_64 is already installed
package perl-4:5.16.3-294.el7_6.x86_64 is already installed
package libuuid-2.23.2-59.el7_6.1.x86_64 is already installed
package clamav-unofficial-sigs-5.6.2-7.el7.noarch is already installed
package util-linux-2.23.2-59.el7_6.1.x86_64 is already installed
package libmount-2.23.2-59.el7_6.1.x86_64 is already installed
package webtop5-webdav-0.1.2-1.ns7.noarch is already installed
package efivar-libs-36-11.el7_6.1.x86_64 is already installed
package python-libs-2.7.5-80.el7_6.x86_64 is already installed
package dbus-1:1.10.24-13.el7_6.x86_64 is already installed
package sope49-gdl1-4.9-20190311_2200.ns7.x86_64 is already installed
package glibc-common-2.17-260.el7_6.6.x86_64 is already installed
package openldap-clients-2.4.44-21.el7_6.x86_64 is already installed
package sope49-ldap-4.9-20190311_2200.ns7.x86_64 is already installed
package NetworkManager-libnm-1:1.12.0-10.el7_6.x86_64 is already installed
package tomcat-jsp-2.2-api-0:7.0.76-9.el7_6.noarch is already installed
package perl-libs-4:5.16.3-294.el7_6.x86_64 is already installed
package mesa-libgbm-18.0.5-4.el7_6.x86_64 is already installed
package sope49-appserver-4.9-20190311_2200.ns7.x86_64 is already installed
package openssl-1:1.0.2k-16.el7_6.1.x86_64 is already installed
package policycoreutils-2.5-29.el7_6.1.x86_64 is already installed
package pulledpork-0.7.3-5.ns7.noarch is already installed
package dbus-libs-1:1.10.24-13.el7_6.x86_64 is already installed
package libsmartcols-2.23.2-59.el7_6.1.x86_64 is already installed
package nethserver-lib-2.2.11-1.ns7.noarch is already installed
package openvpn-2.4.7-1.el7.x86_64 is already installed
package libkadm5-1.15.1-37.el7_6.x86_64 is already installed
package libgcc-4.8.5-36.el7_6.2.x86_64 is already installed
package NetworkManager-1:1.12.0-10.el7_6.x86_64 is already installed
package webtop5-1.2.15-1.ns7.noarch is already installed
yum clean all finishes with no comments.
yum update fails at the transaction check with the following error, and I am totally lost::
–> Finished Dependency Resolution
–> Running transaction check
—> Package kernel.x86_64 0:3.10.0-862.6.3.el7 will be erased
Error: Multilib version problems found. This often means that the root
cause is something else and multilib version checking is just
pointing out that there is a problem. Eg.:
1. You have an upgrade for libgcc which is missing some
dependency that another package requires. Yum is trying to
solve this by installing an older version of libgcc of the
different architecture. If you exclude the bad architecture
yum will tell you what the root cause is (which package
requires what). You can try redoing the upgrade with
--exclude libgcc.otherarch ... this should give you an error
message showing the root cause of the problem.
2. You have multiple architectures of libgcc installed, but
yum can only see an upgrade for one of those architectures.
If you don't want/need both architectures anymore then you
can remove the one with the missing update and everything
will work.
3. You have duplicate versions of libgcc installed already.
You can use "yum check" to get yum show these errors.
...you can also use --setopt=protected_multilib=false to remove
this checking, however this is almost never the correct thing to
do as something else is very likely to go wrong (often causing
much more problems).
Protected multilib versions: libgcc-4.8.5-36.el7_6.2.i686 != libgcc-4.8.5-36.el7.x86_64
So this lead to the question: why server has installed libgcc, glibc and libstdc i686 instead of x86_64?
What software did you installed on the nethserver more than modules?
Maybe yum deplist libgcc and so on could help to find it.
Consider also to use tag “code” (ctrl+shift+c) into posts for improve reading of output.
nethserver-updates: mirror.nethserver.org
package: libgcc.i686 4.8.5-36.el7_6.2
No dependencies for this package
package: libgcc.x86_64 4.8.5-36.el7_6.2
Ok, i posted the “wrong” command.
I would like to know which package used the libraries as dependancy, but i searched the opposite (which dependencies the libraries has).
I am not skilled or experienced enough to know if it’s safe to remove libgcc, glibc and libstdc with i686 (even i am not sure i know how to do that…)
[root@juliet ~]# yum remove *.i686
Loaded plugins: auto-update-debuginfo, changelog, fastestmirror,
: nethserver_events
Resolving Dependencies
There are unfinished transactions remaining. You might consider running yum-complete-transaction, or "yum-complete-transaction --cleanup-only" and "yum history redo last", first to finish them. If those don't work you'll have to try removing/installing packages by hand (maybe package-cleanup can help).
--> Running transaction check
---> Package audit-libs.i686 0:2.8.4-4.el7 will be erased
---> Package bzip2-libs.i686 0:1.0.6-13.el7 will be erased
---> Package cracklib.i686 0:2.9.0-11.el7 will be erased
---> Package elfutils-libelf.i686 0:0.172-2.el7 will be erased
---> Package elfutils-libs.i686 0:0.172-2.el7 will be erased
---> Package glibc.i686 0:2.17-260.el7 will be erased
---> Package libattr.i686 0:2.4.46-13.el7 will be erased
---> Package libcap.i686 0:2.22-9.el7 will be erased
---> Package libcap-ng.i686 0:0.7.5-4.el7 will be erased
---> Package libdb.i686 0:5.3.21-24.el7 will be erased
---> Package libgcc.i686 0:4.8.5-36.el7 will be erased
---> Package libgcrypt.i686 0:1.5.3-14.el7 will be erased
---> Package libgpg-error.i686 0:1.12-3.el7 will be erased
---> Package libselinux.i686 0:2.5-14.1.el7 will be erased
---> Package libsepol.i686 0:2.5-10.el7 will be erased
---> Package libstdc++.i686 0:4.8.5-36.el7 will be erased
---> Package lz4.i686 0:1.7.5-2.el7 will be erased
---> Package nss-softokn-freebl.i686 0:3.36.0-5.el7_5 will be erased
---> Package pam.i686 0:1.1.8-22.el7 will be erased
---> Package pcre.i686 0:8.32-17.el7 will be erased
---> Package rdma-core.i686 0:17.2-3.el7 will be erased
---> Package systemd-libs.i686 0:219-62.el7 will be erased
---> Package xz-libs.i686 0:5.2.2-1.el7 will be erased
---> Package zlib.i686 0:1.2.7-18.el7 will be erased
Dependencies Resolved
Package Arch Version Repository Size
Removing:
audit-libs i686 2.8.4-4.el7 @base 244 k
bzip2-libs i686 1.0.6-13.el7 @base 76 k
cracklib i686 2.9.0-11.el7 @base 186 k
elfutils-libelf i686 0.172-2.el7 @base 899 k
elfutils-libs i686 0.172-2.el7 @base 757 k
glibc i686 2.17-260.el7 @base 15 M
libattr i686 2.4.46-13.el7 @base 19 k
libcap i686 2.22-9.el7 @base 100 k
libcap-ng i686 0.7.5-4.el7 @base 44 k
libdb i686 5.3.21-24.el7 @base 1.8 M
libgcc i686 4.8.5-36.el7 @base 190 k
libgcrypt i686 1.5.3-14.el7 @base 608 k
libgpg-error i686 1.12-3.el7 @base 337 k
libselinux i686 2.5-14.1.el7 @base 206 k
libsepol i686 2.5-10.el7 @base 690 k
libstdc++ i686 4.8.5-36.el7 @base 997 k
lz4 i686 1.7.5-2.el7 @base 356 k
nss-softokn-freebl i686 3.36.0-5.el7_5 @updates 499 k
pam i686 1.1.8-22.el7 @base 2.4 M
pcre i686 8.32-17.el7 @base 1.4 M
rdma-core i686 17.2-3.el7 @base 101 k
systemd-libs i686 219-62.el7 @base 1.3 M
xz-libs i686 5.2.2-1.el7 @base 245 k
zlib i686 1.2.7-18.el7 @base 180 k
Transaction Summary
Remove 24 Packages
Installed size: 28 M
Yaay - I now have a fully updated system and no apparent issues. Both pam and systemd-libs are present at listed versions.
I want to thank you guys for helping me out. Great community. And who knows I might have learned a thing or two from this.
Thanks again.
I removed all the .i686 files, ran yum clean all and then yum update. After those 330 updates there was one new update, which I cleared in the same manner. BTW I have current backups so I was not too worried about removing the 32 bit files, now I just hope they stay away.
Thanks again.
