We have a separate disk in one of our nethservers, which is mounted @ /var/lib/nethserver/ibay
I would like to know if and how it is possible to see it in cockpit/system/disk usage menu too.
Thanks for your post, but I am talking about the disk usage tab, not the storage tab.
Thanks, I had removed the analyze only the root filesystem and saved, but it had no effect, because I did not see the update now.
