Switched to NethSecurity (on arm64)
Gentle bump: any new on this.
I’m asking because with the release of Nethsecurity 8.7.2 more functionality (live flows) depend on netifyd. I cloud try to build Nethsecurity with netifyd 5.x.x from the public sources published on the Netify Gitlab. However, I think that’s not going to help much, the Flow Actions Processor Plugin seems to be closed source.
From the netify website:
This guide covers installation of Netify Agent v5 for OpenWrt on x86 architecture. If you require support for ARM, MIPS, or other hardware platforms, please contact us - we have additional builds available for many targets.
Could contact them directly but I guess they do not give de closed source builds to me. :thinking:
Why not. They specifically state to contact them, so why not contact them?
Sadly, no, I’ll give them a bump.
By compiling it yourself you’ll sadly lose:
  • Aggregator Plugin, which is found in “Top Talkers” tab, and down on the line will replace even the handmade one we’ve built for the “Daily Traffic” tab, both in the Monitoring section
  • Flow Actions Processor Plugin which is the filter for the “DPI filters”
The live flows is something we’ve built from their open source components, so it will be present in the build.
You could try to contact them, they are pretty open to dialogue. Maybe they’ll provide us with the needed pieces to make it happen.
Oke, I will contact and them and reference this thread.
Hello,
My name is Ruben, I came across Nethsecurity project which is a very interesting openwrt based project.
I have been recently following its development and I am particularly interested in the possibility of running it on an ARM64 architecture.
I was wondering if there is any update to netifyd v5 pre-compiled binaries, which would facilitate support for arm64 architectures.
Could you please provide an update on the status of this integration?
Thanks in advance
Ruben
Hi Ruben, Welcome to the Nethserver community!
There are some rumors the precomplied binaries for netifyd v5.x are in the making.
So lets hope those rumors are true.
To be frank, I kind of paused the (back)port to ARM64 awaiting a solution for netifyd. Did some research compiling netifd 5.x from the open sources in the (Openwrt) build tree, but haven’t figured this out yet. Again, fingers crossed. :hand_with_index_finger_and_thumb_crossed:
Out of curiosity, which ARM64 hardware are you aiming for?
Hi Mark,
Thanks a lot for the warm welcome.
Ok, lets keep our fingers crossed.
Do you know what might be the reason for such reluctance from netify to provide the netifyd binaries for arm64?
I’ve a nanopi R76S which is compatible with newest releases of Openwrt, although I would like to use Nethsecurity.
I’ve managed to run Nethsecurity on a docker container on a orangepi5 plus and really liked this firewall.
Regards
To my understanding it’s because of the integration in their automated workflow (CI), which is feasible because you do not want to create a manual build for ARM64 every update.
Nethsecurity is still on the Openwrt 24.x branch but in time it most certainly goes to 25.x.
Hello Mark,
Have you managed to contact netify?
Thanks
Ruben
Sorry I missed your reply/question.
However the binaries have arrived and are hosted in the nethsecurity testing repositories.
Even if needs some further coordination on aarch/target names, a first test build (8.8.0 beta-1 based on openwrt 25.12.4) for the 64 bit armsr target succeeded including netifyd-5.2.8.
Still need to install and test the results and foremost dive in to {signing, serving} apk- instead of ipk packages.
Here are the test build results / changes:
(links could be short lived due to further development)
Hello everyone!
I can confirm that we’ve got netifyd binaries for aarch64, the PR related is here: chore(netifyd): updated to 5.2.8 by Tbaile · Pull Request #1729 · NethServer/nethsecurity · GitHub
I’ve already published the fixed package as Mark was hinting, since I’ve spotted an issue with netifyd 5.2.8, that upstream devs quickly fixed. Also mark found out an issue with the initial build of netifyd for arm, which it’s addressed.
OpenWRT changed how to sign packages, here’s the commit with the changes we’ve applied: build: updated signing method for APKs (#1659) · NethServer/nethsecurity@b9806ff · GitHub , and here’s the DEV manual regard the sign: Build system | NethSecurity . Most likely you’ll just need to generate the keys, since the serving of the packages is the same.
Hope this helps!
This great news!
Yes sure (the change in .gitignore hinted something changed here)
Wil get on with it the coming day’s and report back to you
So far so good :trumpet:
The armsr image booted out of the box as a (emulated) qemu-vm; first boot wizard worked fine and no more missing /etc/config/dpi as we have the fully fledged nethifyd on aarch64:
root@NethSec:/etc/config# cat dpi
config main ‘config’
option log_blocked ‘0’
option enabled ‘1’
option firewall_exemption ‘0’
list popular_filters ‘netify.facebook’
list popular_filters ‘netify.amazon-prime’
list popular_filters ‘netify.whatsapp’
list popular_filters ‘netify.instagram’
list popular_filters ‘netify.netflix’
list popular_filters ‘netify.telegram’
list popular_filters ‘netify.tiktok’
list popular_filters ‘netify.youtube’
list popular_filters ‘netify.facebook-messenger’
list popular_filters ‘netify.twitter’
list popular_filters ‘netify.vimeo’
list popular_filters ‘netify.snapchat’
list popular_filters ‘netify.pinterest’
list popular_filters ‘netify.nordvpn’
list popular_filters ‘DoT’
list popular_filters ‘netify.twitch’
list popular_filters ‘netify.teamviewer’
list popular_filters ‘DoH’
config rule ‘ns_bcc7c4a6’
option enabled ‘1’
option device ‘br-lan’
option action ‘block’
list application ‘netify.facebook’
list application ‘netify.amazon-prime’
list application ‘netify.instagram’
list application ‘netify.twitch’
list application ‘netify.pinterest’
list application ‘netify.twitter’
list application ‘netify.tiktok’
list application ‘netify.netflix’
list application ‘netify.youtube’
list application ‘netify.vimeo’
list application ‘netify.snapchat’
list protocol ‘DoT’
list protocol ‘DoH’
So no more choking of pyrhon3-nethsec when creating “objects” such as DNS records. :+1:
Liveflows seems to work:
Still need to iron out a few wrinkles such as a custom URL for the package repository Speaking of which: kudos the arch isn’t hard-coded in the feeds list any more. :+1:
Also need to do some real life testing…anyways so far so good :trumpet:
For real life testing installed my custom 8.8.0-beta1 on my daily driver the Nanopi R5S:
Was not able to update from 8.7.1 to 8.8.0-beta and also was not able to restore a backup config from 8.7.1
It booted out of the box and after manually setting all stuff up again everything seems to work oke :smiley:
I’m quite happy now netify is sorted out :smiley:
To be frank I thought is was becoming not feasible to run Nethsecurity on arm devices… but most definitely the opposite happened. :+1:
Besides 2 missing build dependencies (python3-dev / python3-pyelftools) for Uboot only the ns-storage package is stubborn.
  1. Already knew ns-storage can not handle the partition naming scheme of SD-cards and eMMC’s which is similar to nvme’s: partitions are numberd px in stead of just a number (x)
mmcblk0 179:96 0 29.7G 0 disk
├─mmcblk0p1 179:97 0 16M 0 part
├─mmcblk0p2 179:98 0 300M 0 part /rom
└─mmcblk0p3 179:99 0 29.3G 0 part /mnt/data
addressed this issue in this commit:
  1. Recently at removal of a permanent storage finding the rootfs / rom partition has changed. Unfortunately now we are looking for the boot-partition instead of the rom-partition. As one can see in the partition scheme above, booting with uboot we do not have a (fat32) boot-partition
Also note the method to find the rom-partition (lsblk -ln | grep "/rom" | uniq | awk '{print $1}') regarded unreliable in remove-storage is still present in ns-storage-setup-partition and ns-storage-has-free-space
  1. Also found a bug in the recently introduced permanent storage of dhcp-leases, the call to get path to the dhcp-lease file in list_active_leases has one argument to much (second " dhcp"):
I’ll likely need a ARM device to iron out everything, it seems we’re at a very good point tho!
I’ve opened a PR for the leases: fix(dhcp): wrong call of euci for uci prop by Tbaile · Pull Request #1738 · NethServer/nethsecurity · GitHub
OT: guess needs to change here to…
Apologies I missed this;
I did a git grep ; missed it as the euci class is initialized as uci instead of u
I wonder if the changes I propose to the ns-storage package can be accepted;
If so i’m going to test them extensive on x86_64 VM’s and hardware;
to open a PR on a pass
Hi Mark,
Some weeks back I’ve notice some github commits which pointed to a netify arm64 support.
Are your builds for nanopi devices working properly?
Thanks
Hi Ruben,
Yes they work for me, iv been using it at home for 2 weeks now.
As a mater of fact i’v build a test image for a nanopi r76s too:
https://repo.havakdev.eu/nethsec-aarch64/8.8.0-beta.1/targets/rockchip/armv8/nethsecurity-8.8.0-beta.1-rockchip-armv8-friendlyarm_nanopi-r76s-squashfs-sysupgrade.img.gz
Please note this is still very rough test image, which as an example needs some manual configuration of the custom package repository.
However I’d be delighted if someone else than me would kick the tires of nethsecurity on ARM64 and report the encountered troubles :slight_smile:
can I get a heartbeat on the aarch64 work? Is this still coming along? It looks encouraging.
Hi @blackbox,
Which hardware are you targeting?
I’m cautiously optimistic as some issues are getting addressed in the main codebase. So by the upcoming release some tweaks/modifications can be dropped.
Not sure I official support will ever materialize, but who knows what the future will bring (even proxmox has an official arm64 repository now)
A community based form of support should be possible;
Meanwhile using nethsecurity on aarch64 as a daily-driver since I opened this thread a year ago. As an opensource adept (and to be sure I do not violate any Licenses) I publish all modifications I made and host the results.
