Hello.
we face the following issue: Some former users were deleted via ldap. …It seems that there were pending activity mails for these users in the outbox that can not be delivered. Each time the cron job runs we get the log entries down below. We first saw this problems after upgrading to 25.0.1 (from 24.0.5).
Is there a way to manually purge this outbox or solve the issue otherwise?
Thanks in advance.
### Server configuration
**Operating system**: Ubuntu 20.04.5
**Web server:** nginx
**Database:** postgresql
**PHP version:** 8.1.12
**Nextcloud version:** 25.0.1.1
**Where did you install Nextcloud from:** docker-compose file
version: '3'
services:
db:
image: postgres:13
restart: always
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
volumes:
- ./db:/var/lib/postgresql/data
env_file:
- db.env
redis:
image: redis
command: redis-server --requirepass ***
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
restart: always
app:
container_name: app-server
image: nextcloud:25.0.1-fpm
restart: always
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
expose:
- '80'
- '9000'
volumes:
- ./nextcloud:/var/www/html
- ./www.overloaded.conf:/usr/local/etc/php-fpm.d/www.overloaded.conf
- ./nextcloud.ini:/usr/local/etc/php/conf.d/nextcloud.ini
environment:
- POSTGRES_HOST=db
- REDIS_HOST=redis
- REDIS_HOST_PASSWORD=***
env_file:
- db.env
depends_on:
- db
- redis
cron:
restart: always
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
volumes:
entrypoint: /cron.sh
depends_on:
- db
- redis
- app
onlyoffice-document-server:
container_name: onlyoffice-document-server
image: onlyoffice/documentserver:7.1
restart: always
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
expose:
- '80'
- '443'
volumes:
- ./document_data:/var/www/onlyoffice/Data
- ./document_log:/var/log/onlyoffice
nginx:
container_name: nginx-server
image: nginx:1.21
restart: always
logging:
driver: "json-file"
options:
max-file: "10"
max-size: "10m"
ports:
- 80:80
- 443:443
volumes:
- ./nginx.conf:/etc/nginx/nginx.conf
- ./cloud-cert.pem:/etc/nginx/cloud-cert.pem
- ./private.pem:/etc/nginx/private.pem
depends_on:
- db
- redis
- app
volumes:
db:
nextcloud:
document_data:
document_log:
app_data:
**Signing status:** Not sure what this means
**Nextcloud configuration:**
"system": {
"minimum.supported.desktop.version": "3.4.1",
"memcache.local": "\\OC\\Memcache\\APCu",
"apps_paths": [
"path": "\/var\/www\/html\/apps",
"url": "\/apps",
"writable": false
"path": "\/var\/www\/html\/custom_apps",
"url": "\/custom_apps",
"writable": true
"memcache.distributed": "\\OC\\Memcache\\Redis",
"memcache.locking": "\\OC\\Memcache\\Redis",
"redis": {
"host": "***REMOVED SENSITIVE VALUE***",
"password": "***REMOVED SENSITIVE VALUE***",
"port": 6379
"instanceid": "***REMOVED SENSITIVE VALUE***",
"passwordsalt": "***REMOVED SENSITIVE VALUE***",
"secret": "***REMOVED SENSITIVE VALUE***",
"trusted_domains": [
"nginx-server"
"default_language": "de",
"default_locale": "de",
"default_phone_region": "de",
"knowledgebaseenabled": true,
"datadirectory": "***REMOVED SENSITIVE VALUE***",
"dbtype": "pgsql",
"version": "25.0.1.1",
"overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
"overwritehost": "***REMOVED SENSITIVE VALUE***",
"overwriteprotocol": "https",
"dbname": "***REMOVED SENSITIVE VALUE***",
"dbhost": "***REMOVED SENSITIVE VALUE***",
"dbport": "",
"dbtableprefix": "oc_",
"dbuser": "***REMOVED SENSITIVE VALUE***",
"dbpassword": "***REMOVED SENSITIVE VALUE***",
"installed": true,
"onlyoffice": {
"DocumentServerUrl": "\/ds-vpath\/",
"DocumentServerInternalUrl": "http:\/\/onlyoffice-document-server\/",
"StorageUrl": "http:\/\/nginx-server\/",
"verify_peer_off": true
"allow_local_remote_servers": "true",
"ldapProviderFactory": "OCA\\User_LDAP\\LDAPProviderFactory",
"mail_from_address": "***REMOVED SENSITIVE VALUE***",
"mail_smtpmode": "smtp",
"mail_sendmailmode": "smtp",
"mail_domain": "***REMOVED SENSITIVE VALUE***",
"mail_smtphost": "***REMOVED SENSITIVE VALUE***",
"mail_smtpport": "25",
"maintenance": false,
"maintenance_window_start": 1,
"mail_smtpauthtype": "PLAIN",
"mail_smtpauth": 1,
"mail_smtpname": "***REMOVED SENSITIVE VALUE***",
"mail_smtppassword": "***REMOVED SENSITIVE VALUE***",
"mail_smtpsecure": "tls",
"auto_logout": false,
"loglevel": 2,
"app_install_overwrite": [
"spreed",
"files_texteditor",
"tasks",
"quota_warning",
"forms",
"files_mindmap",
"files_bpm",
"drawio"
### Logs
#### Nextcloud log (data/nextcloud.log)
[activity] Warnung: Failed sending activity email to user '3ef6d5ba-f34d-103a-9a21-73d5657b9a5b'. at 2022-11-08T13:10:02+00:00
[activity] Fehler: Swift_TransportException: Expected response code 354 but got code "554", with message "554 5.5.1 Error: no valid recipients" at <<closure>>
0. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 344
Swift_Transport_AbstractSmtpTransport->assertResponseCode("554 5.5.1 Error ... n", [354])
1. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/EsmtpTransport.php line 305
Swift_Transport_AbstractSmtpTransport->executeCommand("DATA\r\n", [354], ["user@user@domain.tld"], false, null)
2. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 392
Swift_Transport_EsmtpTransport->executeCommand("DATA\r\n", [354], ["user@user@domain.tld"])
3. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 499
Swift_Transport_AbstractSmtpTransport->doDataCommand(["user@domain.tld"])
4. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 518
Swift_Transport_AbstractSmtpTransport->doMailTransaction(Swift_Message {}, "cloudmail@domain.tld", ["user@domain.tld"], ["user@domain.tld"])
5. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 206
Swift_Transport_AbstractSmtpTransport->sendTo(Swift_Message {}, "cloudmail@domain.tld", ["3ef6d5ba-f34d-103a-9a21-73d5657b9a5b"], ["user@domain.tld"])
6. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Mailer.php line 71
Swift_Transport_AbstractSmtpTransport->send(Swift_Message {}, ["user@domain.tld"])
7. /var/www/html/lib/private/Mail/Mailer.php line 191
Swift_Mailer->send(Swift_Message {}, ["user@domain.tld"])
8. /var/www/html/apps/activity/lib/MailQueueHandler.php line 415
OC\Mail\Mailer->send(OC\Mail\Message {})
9. /var/www/html/apps/activity/lib/MailQueueHandler.php line 165
OCA\Activity\MailQueueHandler->sendEmailToUser("3ef6d5ba-f34d-103a-9a21-73d5657b9a5b", "user@domain.tld", "de", "Europe/Berlin", 1667913000)
10. /var/www/html/apps/activity/lib/BackgroundJob/EmailNotification.php line 61
OCA\Activity\MailQueueHandler->sendEmails(500, 1667913000)
11. /var/www/html/lib/private/BackgroundJob/Job.php line 54
OCA\Activity\BackgroundJob\EmailNotification->run(null)
12. /var/www/html/lib/private/BackgroundJob/TimedJob.php line 60
OC\BackgroundJob\Job->execute(OC\BackgroundJob\JobList {}, OC\Log {})
13. /var/www/html/cron.php line 152
OC\BackgroundJob\TimedJob->execute(OC\BackgroundJob\JobList {}, OC\Log {})
[PHP] Fehler: Error: strtolower(): Passing null to parameter #1 ($string) of type string is deprecated at /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/EsmtpTransport.php#144 at <<closure>>
0. <<closure>>
OC\Log\ErrorHandler::onError(8192, "strtolower(): P ... d", "/var/www/html/3 ... p", 144)
1. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/EsmtpTransport.php line 144
strtolower(null)
2. /var/www/html/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/SmtpTransport.php line 43
Swift_Transport_EsmtpTransport->setEncryption(null)
3. /var/www/html/lib/private/Mail/Mailer.php line 267
Swift_SmtpTransport->__construct()
4. /var/www/html/lib/private/Mail/Mailer.php line 254
OC\Mail\Mailer->getSmtpInstance()
5. /var/www/html/lib/private/Mail/Mailer.php line 180
OC\Mail\Mailer->getInstance()
6. /var/www/html/apps/activity/lib/MailQueueHandler.php line 415
7. /var/www/html/apps/activity/lib/MailQueueHandler.php line 165
OCA\Activity\MailQueueHandler->sendEmailToUser("3ef6d5ba-f34d-103a-9a21-73d5657b9a5b", "user@domain.tld, "de", "Europe/Berlin", 1667913899)
8. /var/www/html/apps/activity/lib/BackgroundJob/EmailNotification.php line 61
OCA\Activity\MailQueueHandler->sendEmails(500, 1667913899)
9. /var/www/html/lib/private/BackgroundJob/Job.php line 54
10. /var/www/html/lib/private/BackgroundJob/TimedJob.php line 60
11. /var/www/html/cron.php line 152
at 2022-11-08T13:25:01+00:00
