Suricata rule category "policy" blocks yum
NethServer Version: 7.4.1708
Module: Suricata IPS
Hi Community,
I found an interesting behaviour in suricata. If I block “Policy” rule category, yum is blocked. Yum-cron is affected too. In evebox I see:
ET POLICY GNU/Linux YUM User-Agent Outbound likely related to package management
Yum update does not work:
[root@nethserver markus]# yum update
Geladene Plugins: changelog, fastestmirror, nethserver_events, priorities
Could not retrieve mirrorlist http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock error was
12: Timeout on http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
Maybe it’s because I just have one green network interface and suricata wants to block client network yum updates?
OK, so just set “Policy” to “Alert” but the problem is that the policy category also includes things like
which I do want to block. All other rule categories I set to block work like a charm. Is there a way to block server attacks and to allow yum?
I don’t use NS for ips… with that in mind, I will say that et policy is not a category I would block.
If your server isn’t vulnerable to poodle, and it should be patched, then that’s not a rule to be concerned with, as is all the rest of the traffic probing for content management vulnerabilities, etc.
Would you want to block this; “ET INFO EXE IsDebuggerPresent (Used in Malware Anti-Debugging)”?
or this; “ET POLICY PE EXE or DLL Windows file download”?
Because if you do, you’re going to create a world of hurt for yourself with any windows machines behind your gateway.
Thanks for this info, I thought there may be really bad attacks in this category.
It’s a managed host, so there are no windows clients just this host with green interface, maybe not a regular scenario for IPS. I hoped I could find a kind of IPS rule whitelist, but I found nothing except of IP whitelisting which is really hard with mirrorlists…
I solved it in a dirty way but changing something in IPS settings in web UI will revert my settings :frowning2:
I set “policy” to block in web UI and set the yum rule in /etc/suricata/rules/ET-emerging-policy.rules to “alert” instead of “drop”.
I tried with templates-custom…but no luck on this.
Tried it on another Nethserver VM with red and green interface but same blocked yum on blocked “policy” rule.
I agree with @fasttech, you should not block the policy category.
Thanks for your recommendations… Just alerting instead of blocking is ok for me and solves it. But what do you think about a line in the wiki/docs about this?
http://docs.nethserver.org/en/v7/suricata.html
Like blocking not recommended, because of client/server updates or libs may be blocked?
Done. Hope it’s clear enough.
Perfect, thank you.
I have a very similar problem to that one of @mrmarkuz…
exactly the same error messages…
I also use suricata. when I turn it off, yum and wget work perfectly fine… however when I turn it on, I get the timeout message mentioned by @mrmarkuz…
however, I already set the “policy” ruleset to alert. neither yum nor wget is working correctly (especially yum… wget is working as long as I don’t try to download the repo file manually).
I don’t know which ruleset of suricata blocks it in my case… any ideas? or how can I see it?
You may use evebox to see which categories are blocked:
http://docs.nethserver.org/en/v7/suricata.html#evebox
Guys need some experts advise here on sericata im not sure if I have set this right so need some advise from the pro’s
Do these settings look right im not sure if I have set this right the services which have alert are services which I will be using externally and internally so I presume I have to have them as alert and not block or it will block those services is that correct
Here are some “safe” settings:
cool thanks
