Wait a sec. I tried something (adding a route) and now nothing works anymore, I have to revert back
Yep, Proxmox is accessed via internet without nat. SSH Port is changed and password login deactivated in favour of certificate based login.
With the bridge I was not successfull yet, so first I try to setup nat connection. Then Iâll try bridge.
I had to reboot server as the route I had added was wrong.
Now to answer your question. No, 8.8.8.8 is not pingable. The external ip is pingable, but not the gateway of the external ip.
But proxmox can ping 8.8.8.8?
Iâd evade using NAT on the virtualization host, at least in your present, specific environment.
Itâs cost you so far a few daysâŠ
yes, let me check on windows vm if its the same. Yep, its the same on windows.
True cost me way to much time, but need it the one way or the other. If I find out, why I cannot reach host gateway from both vms then probably bridged connection will work too.
I am able to set external host nic to manual, and then give the external ip to virbr0. That works, and so I still can connect to the host via ssh. I can try that again. But as long as the gateway does not reply I am bit lost.
Shall I post config of /etc/network/interfaces?
Windows VM can ping 8.8.8.8?
What does that windows use as gateway?
No, both câant ping 8.8.8.8 nor the host gateway. Gateway is on vms is 192.168.57.1(configured on the network card).
Excactly
so only proxmox has external access?
yes, although /proc/sys/net/ipv4/ip_forward -> 1
It must be something stupid, maybe a typoâŠ
Yes, post your network config.
My background is networking after all, not programming.
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto enp26s0
iface enp26s0 inet static
address 82.220.38.12
gateway 82.220.38.1
netmask 255.255.255.0
iface enp24s0 inet manual
auto vmbr0
iface vmbr0 inet static
address 10.0.57.1
bridge-ports none
bridge-stp off
bridge-fd 0
post-up echo 1 > /proc/sys/net/ipv4/ip_forward
post-up iptables -t nat -A POSTROUTING -s '10.0.57.0/24' -o enp26s0 -j MASQUERADE
post-down iptables -t nat -D POSTROUTING -s '10.0.57.0/24' -o enp26s0 -j MASQUERADE
auto vmbr1
iface vmbr1 inet static
address 192.168.57.1
bridge-ports none
bridge-stp off
bridge-fd 0
post-up iptables -t nat -A POSTROUTING -s '192.168.57.0/24' -o enp26s0 -j MASQUERADE
post-down iptables -t nat -D POSTROUTING -s '192.168.57.0/24' -o enp26s0 -j MASQUERADE
Thank you so much, I feel sorry and thankfull the same time for stealing your time! Is there anything to check that should be enabled within proxmox webinterface for enabling external access to the vms?
Just to clarify:
Are there ANY files in /etc/network/interfaces.d/ ?
All my configuration at the illustrated site seems to be only in the file /etc/network/interfaces.
No, its empty, must have been created by debian or something. But I have two old interfaces_backup and /interfaces_backup2 in /etc/network, but they should not interfear? I can delete them, restart network and try again, just to be sure
Wait, try this:
The configuration of my /etc/network/interfaces.d/ is empty.
As per https://pve.proxmox.com/wiki/Network_Configuration
Network configuration can be done either via the GUI, or by manually editing the file /etc/network/interfaces, which contains the whole network configuration.
My /etc/network/interfaces file looks like as follows, without the warning lines at the beginning:
auto lo
iface eno1 inet manual
iface eno2 inet manual
auto vmbr0
address 192.168.209.61
gateway 192.168.209.1
bridge_ports eno1
bridge_stp off
bridge_fd 0
auto vmbr1
iface vmbr1 inet manual
bridge_ports eno2
bridge_stp off
bridge_fd 0
The warning lines are:
network interface settings; autogenerated
Please do NOT modify this file directly, unless you know what
youâre doing.
If you want to manage part of the network configuration manually,
please utilize the âsourceâ or âsource-directoryâ directives to do
so.
PVE will preserve these directives, but will NOT its network
configuration from sourced files, so do not attempt to move any of
the PVE managed interfaces into external files!
All these lines start with a â#ââŠ
Try replicating this and adapt your config (IPs)
Both Bridges can have an IP, one the external IP, the second your internal IP (192.168.57.x?).
Evade using the IPs 1 or 254, unless that box is your router!
The main thing missing in your config is the Gateway of that partcular subnet.
Note:
In my example above vmbr1 is connected to a VDSL connection, so here Proxmox doesnât need an IP and is not accessible on this connection. It just passes everything through.
That maybe it, Iâll remove the .1 and add gateway.
Hm, did not work, same result. I changed adress on vmbr1 to 192.168.57.3, gateway 192.168.57.1 but same thing. Let my try something else. I wipe my configuration and try with your settings.
I start thinking it could be something within proxmox that I maybe need to activate?
That sounds better. (Keep a copy anyway)
â On a normal settup of Proxmox thereâs no additional setting need to be set to access your VMs, and they are âbridgedâ as expected.
I think these âissuesâ are a residual of setting up via Debian.
Wait, I maybe see the error. I have bridge-ports none where you have your nic name there. Let me test. Ah, no thats the brigded variant. So Iâll do that, wait.
Maybe, yes, but I had no other choice, as its what the hoster offers
Debian âUmwegâ, halt notwendiges ĂŒbelâŠ
Yep. Ich stell grad auf bridged um. sekunde
Ok, now interfaces has been changed to brigded. Now rebooting nethserver to see, what I have to configure there
