NethServer Version: 6.9rc1
Module: Server Certificate
Beginning with Chrome 58, this version no longer supports CN for certificates and requires SubjectAltNames. Has anyone successfully create a cert in NethServer with SAN?
I just figured out how to fix it…
The /etc/pki/tls/openssl.cnf file needs to be updated.
I’m in the process of updating all of my certs across all of my computers at the moment. Then I will compare the original openssl.cnf to the modified one and provide it here and speak to it’s changes.
Quick summary of changes. Apologize for the formatting, I copied the entire contents of my new file below the summary of changes.
Under [ Req ] section
Removed line: default_md = sha1
uncommented: req_extensions = v3_req
Under [ v3_req ] section
Added: extendedKeyUsage = serverAuth
Added: subjectAltName = @alt_names
Under [ v3_ca ] section
Added new section [ alt_names ] at the bottom of the file with DNS and IP format that follows.
[ alt_names ]
DNS.1 = example.com
DNS.2 = www.example.com
IP.1 = 10.10.1.207
IP.2 = 10.10.1.209
OpenSSL example configuration file.
This is mostly being used for generation of certificate requests.
This definition stops the following lines choking if HOME isn’t
defined.
HOME = .
RANDFILE = $ENV::HOME/.rnd
Extra OBJECT IDENTIFIER info:
#oid_file = $ENV::HOME/.oid
oid_section = new_oids
To use this configuration file with the “-extfile” option of the
“openssl x509” utility, name here the section containing the
X.509v3 extensions to use:
extensions =
(Alternatively, use a configuration file that has only
X.509v3 extensions in its main [= default] section.)
[ new_oids ]
We can add new OIDs in here for use by ‘ca’, ‘req’ and ‘ts’.
Add a simple OID like this:
testoid1=1.2.3.4
Or use config file substitution like this:
testoid2=${testoid1}.5.6
Policies used by the TSA examples.
tsa_policy1 = 1.2.3.4.1
tsa_policy2 = 1.2.3.4.5.6
tsa_policy3 = 1.2.3.4.5.7
[ ca ]
default_ca = CA_default # The default ca section
[ CA_default ]
#dir = ./demoCA # Where everything is kept
dir = /etc/pki/CA
certs = $dir/certs # Where the issued certs are kept
crl_dir = $dir/crl # Where the issued crl are kept
database = $dir/index.txt # database index file.
#unique_subject = no # Set to ‘no’ to allow creation of
# several ctificates with same subject.
new_certs_dir = $dir/newcerts # default place for new certs.
certificate = $dir/cacert.pem # The CA certificate
#certificate = /etc/pki/tls/cert.pem
serial = $dir/serial # The current serial number
crlnumber = $dir/crlnumber # the current crl number
# must be commented out to leave a V1 CRL
crl = $dir/crl.pem # The current CRL
private_key = $dir/private/cakey.pem # The private key
#private_key = /etc/pki/tls/private/httpd-admin.key
RANDFILE = $dir/private/.rand # private random number file
x509_extensions = usr_cert # The extentions to add to the cert
Comment out the following two lines for the “traditional”
(and highly broken) format.
name_opt = ca_default # Subject Name options
cert_opt = ca_default # Certificate field options
Extension copying option: use with caution.
copy_extensions = copy
Extensions to add to a CRL. Note: Netscape communicator chokes on V2 CRLs
so this is commented out by default to leave a V1 CRL.
crlnumber must also be commented out to leave a V1 CRL.
crl_extensions = crl_ext
default_days = 3650 # how long to certify for
default_crl_days= 30 # how long before next CRL
default_md = default # use public key default MD
preserve = no # keep passed DN ordering
A few difference way of specifying how similar the request should look
For type CA, the listed attributes must be the same, and the optional
and supplied fields are just that
policy = policy_match
For the CA policy
[ policy_match ]
countryName = match
stateOrProvinceName = match
organizationName = match
organizationalUnitName = optional
commonName = supplied
emailAddress = optional
For the ‘anything’ policy
At this point in time, you must list all acceptable ‘object’
types.
[ policy_anything ]
countryName = optional
stateOrProvinceName = optional
localityName = optional
organizationName = optional
[ req ]
default_bits = 2048
#default_keyfile = privkey.pem
distinguished_name = req_distinguished_name
attributes = req_attributes
x509_extensions = v3_ca # The extentions to add to the self signed cert
Passwords for private keys if not present they will be prompted for
input_password = secret
output_password = secret
This sets a mask for permitted string types. There are several options.
default: PrintableString, T61String, BMPString.
pkix : PrintableString, BMPString (PKIX recommendation before 2004)
utf8only: only UTF8Strings (PKIX recommendation after 2004).
nombstr : PrintableString, T61String (no BMPStrings or UTF8Strings).
MASK:XXXX a literal mask value.
WARNING: ancient versions of Netscape crash on BMPStrings or UTF8Strings.
string_mask = utf8only
req_extensions = v3_req # The extensions to add to a certificate request
[ req_distinguished_name ]
countryName = Country Name (2 letter code)
countryName_default = XX
countryName_min = 2
countryName_max = 2
stateOrProvinceName = State or Province Name (full name)
stateOrProvinceName_default = StateProvince
localityName = Locality Name (eg, city)
0.organizationName = Organization Name (eg, company)
0.organizationName_default =
we can do this but it is not needed normally
#1.organizationName = Second Organization Name (eg, company)
#1.organizationName_default =
organizationalUnitName = Organizational Unit Name (eg, section)
organizationalUnitName_default = none
commonName = Common Name (e.g. server FQDN or YOUR name)
commonName_max = 64
emailAddress = Email Address
emailAddress_max = 64
SET-ex3 = SET extension number 3
[ req_attributes ]
challengePassword = A challenge password
challengePassword_min = 4
challengePassword_max = 20
unstructuredName = An optional company name
[ usr_cert ]
These extensions are added when ‘ca’ signs a request.
This goes against PKIX guidelines but some CAs do it and some software
requires this to avoid interpreting an end user certificate as a CA.
basicConstraints=CA:FALSE
Here are some examples of the usage of nsCertType. If it is omitted
the certificate can be used for anything except object signing.
This is OK for an SSL server.
nsCertType = server
For an object signing certificate this would be used.
nsCertType = objsign
For normal client use this is typical
nsCertType = client, email
and for everything including object signing:
nsCertType = client, email, objsign
This is typical in keyUsage for a client certificate.
keyUsage = nonRepudiation, digitalSignature, keyEncipherment
This will be displayed in Netscape’s comment listbox.
nsComment = “OpenSSL Generated Certificate”
PKIX recommendations harmless if included in all certificates.
subjectKeyIdentifier=hash
authorityKeyIdentifier=keyid,issuer
This stuff is for subjectAltName and issuerAltname.
Import the email address.
subjectAltName=email:copy
An alternative to produce certificates that aren’t
deprecated according to PKIX.
subjectAltName=email:move
Copy subject details
issuerAltName=issuer:copy
#nsCaRevocationUrl = http://www.domain.dom/ca-crl.pem
#nsBaseUrl
#nsRevocationUrl
#nsRenewalUrl
#nsCaPolicyUrl
#nsSslServerName
This is required for TSA certificates.
extendedKeyUsage = critical,timeStamping
[ v3_req ]
Extensions to add to a certificate request
basicConstraints = CA:FALSE
[ v3_ca ]
subjectAltName = @alt_namesExtensions for a typical CA
PKIX recommendation.
authorityKeyIdentifier=keyid:always,issuer
This is what PKIX recommends but some broken software chokes on critical
extensions.
#basicConstraints = critical,CA:true
So we do this instead.
basicConstraints = CA:true
Key usage: this is typical for a CA certificate. However since it will
prevent it being used as an test self-signed certificate it is best
left out by default.
keyUsage = cRLSign, keyCertSign
Some might want this also
nsCertType = sslCA, emailCA
Include email address in subject alt name: another PKIX recommendation
Copy issuer details
DER hex encoding of an extension: beware experts only!
obj=DER:02:03
Where ‘obj’ is a standard or added object
You can even override a supported extension:
basicConstraints= critical, DER:30:03:01:01:FF
[ crl_ext ]
CRL extensions.
Only issuerAltName and authorityKeyIdentifier make any sense in a CRL.
[ proxy_cert_ext ]
These extensions should be added when creating a proxy certificate
nsCertType = server
#nsBaseUrl
#nsRevocationUrl
#nsRenewalUrl
#nsCaPolicyUrl
#nsSslServerName
This really needs to be in place for it to be a proxy certificate.
proxyCertInfo=critical,language:id-ppl-anyLanguage,pathlen:3,policy:foo
[ tsa ]
default_tsa = tsa_config1 # the default TSA section
[ tsa_config1 ]
These are used by the TSA reply generation only.
#dir = ./demoCA # TSA root directory
dir = /etc/pki
serial = $dir/tsaserial # The current serial number (mandatory)
crypto_device = builtin # OpenSSL engine to use for signing
signer_cert = $dir/tsacert.pem # The TSA signing certificate
# (optional)
certs = $dir/cacert.pem # Certificate chain to include in reply
# (optional)
signer_key = $dir/private/tsakey.pem # The TSA private key (optional)
default_policy = tsa_policy1 # Policy if request did not specify it
# (optional)
other_policies = tsa_policy2, tsa_policy3 # acceptable policies (optional)
digests = md5, sha1 # Acceptable message digests (mandatory)
accuracy = secs:1, millisecs:500, microsecs:100 # (optional)
clock_precision_digits = 0 # number of digits after dot. (optional)
ordering = yes # Is ordering defined for timestamps?
# (optional, default: no)
tsa_name = yes # Must the TSA name be included in the reply?
ess_cert_id_chain = no # Must the ESS cert id chain be included?
[ alt_names ]
DNS.1 = example.com
DNS.2 = www.example.comIP.1 = 192.168.1.207
IP.2 = 10.10.1.209
IP.3 = 10.10.2.211
