NethServer Version: 7.3.1611
Module: Log
I realized that in /var/log/messages there are many lines with
dbus[714]: [system] Rejected: destination has a full message queue, 0 matched rules; type=“signal”, sender="(unset)" ((bus)) interface=“org.freedesktop.DBus” member=“NameOwnerChanged” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.DBus” (uid=995 pid=766 comm="/usr/bin/perl /usr/libexec/nethserver/smwingsd ")
what does it mean?
thanks
best regards
AFAIK, those messages are harmless and appear when the smwingsd service is stopped.
Check if it’s running and restart if it is not.
# systemctl status smwingsd
● smwingsd.service - Server Manager DB cache Daemon
Loaded: loaded (/usr/lib/systemd/system/smwingsd.service; static; vendor preset: disabled)
Active: active (running) since Tue 2018-05-15 11:43:35 CEST; 1 day 1h ago
Docs: https://github.com/NethServer/nethserver-httpd-admin
Main PID: 1062 (smwingsd)
CGroup: /system.slice/smwingsd.service
└─1062 /usr/bin/perl /usr/libexec/nethserver/smwingsd
systemctl restart smwingsd
Problem solved !
Thanks Filippo
