Strange behaviour if usernames contain certain characters
NethServer release 7.6.1810 (final)
Kernel release: 3.10.0-957.12.2.el7.x86_64
A few days ago i tried to change a username (the full name of a AD user) in the httpd-admin panel and has made a typo. The typo was the “-” in front of the “Name” and i have saved this without noting this typo. The result was a new Name like “/usr/libexec/openssh/sftp-server” in the Name field.
I think this is not the desired behavior of nethserver and maybe a bigger problem in the back?
Rre-changing the Name was no problem, but maybe someone can check it out.
Regards
yummiweb
Confirmed.
This does not affect the “Remote SSH” setting in any way. I tested with phpldapadmin.
I assume the “-” breaks the field numbering in a way and writes the shell to givenName and displayName fields in LDAP but I can’t locate it in the code.
Hi @yummiweb,
welcome to the NethServer Community! Many thank you for your bug report!
I just filed a new bug for this:
https://github.com/NethServer/dev/issues/5764
As it’s reproducible with both Nethgui and Cockpit, and despite the accounts provider type I guess the bug is in the nethserver-sssd code.
Apart from that, a person name starting with a symbol could not be accepted by the validator… :thinking:
There’s a bug fix to test! Run the following command and check the entered Name value is assigned to the user:
yum --enablerepo=nethserver-testing update nethserver-lib
To revert
yum --noplugins downgrade nethserver-lib
Patch here: https://github.com/NethServer/nethserver-lib/pull/17
It works in Nethgui and Cockpit. :+1:
Thank you @mrmarkuz, the fix was released!
