NethServer Version: 7.8.2003
Module: New UI, system -> storage
This is a fresh install on ESXi 6.7u3, and after I finished the installation, I added a 6tb vm drive. The old how-to on this site was written in 2015. I’m sure that the cli process will work to create the partitions and format, but I’d like to know why the ui cannot handle it? The buttons are grayed out.
Can a new how-to be written to update to the new ui method? I’m trying to avoid using the cli with Neth as I would prefer not to go under the hood every time I need to do something basic, and this install is only to serve as a file host.
