Static route and GUI
Hi. I’ve been using Nethserver and everything is working well. However, after adding a single static route on a green network (I only have red and green) I found the GUI on :980 stops responding? Anyone else seen this?
It was only a single /24 prefix so cant see how if broke the GUI, however even after a reboot and removing the static route from routes-eth1 still no admin GUI?
Hi Dan welcome on NethServer Community,
which type of route did you added and deleted? show me
db networks show
Check on the service panel if httpd-admin is started
Let me know
show
db routes show
Weirdly, If I configure static routes in the Nethserver GUI i’ll lose the GUI, if i do it in CENTOS in /etc/sysconfig/network-scripts/route-eth1 its fine.
