With SME9 I can do it with: /etc/startmail
Is there a similar CLI command to start the mailfetching (getmail) immediately ?
I use this command, it is from /etc/cron.d/getmail
/usr/bin/flock -n -E 0 /var/lib/getmail/username@mydomain.at.cfg -c “/usr/bin/getmail --getmaildir /var/lib/getmail/ --rcfile /var/lib/getmail/username@mydomain.at.cfg --quiet”
I created an alias in .bashrc …
If it works mark your answer as solution please.
