So I would like some help by means of remote access. I installed everything fine, but when accessing the test site with formtools I get a blank page. The logs do not tell me much (other then half the world would like to hack the server)
Any takers to have a quick look pls? Ping me in a pm. Thanks!
[NooB]
How to quickly create an ‘ibay’ called myapp, activate PHP SCL and extra modules? I now have drped my files in /var/www/html manually but I think best is in an ibay.
Best would be to use a vhost - create that from the old server manager to get a nice name, the new Cockpit can also be used, gives you a “random” directory name.
I can only repeat what I’ve heard… The reason is security. A random folder name makes it really hard for hackers to guess the structure.
But it also makes life difficult for those who maintain the server. A “speaking” names tells enough, but add in additional lookup tables to find out which folder is used for which website…
So it’s a compromise, use whatever you feel comfortable with - there are good reasons for both ways…
In this case no vhost is needed, only tomcat8. I followed the quick setup.
I can browse http://nethserver:8080/orbeon/ but I can’t create a form or save it without errors. To be continued…
Thanks so much @mrmarkuz!! I followed it to the letter, but when accessing the URL, I get a time out. The logs (messages, httpd or tomcat) don;t tell me anything.
It could well be my mistake, so I will revert back to a new clean machine and try again.
I wonder where the DB credentials should be used. Within Orbeon, when creating a form, the error “An error occurred while reading form metadata.” may be an indication that the form metadata can not be stored in the DB?
