First time I have had some issues with nethserver that I couldn’t solve from reading the forum.
After upgrading from 7.8, sssd, nmb, smb and winbind will not start. sssd gets the status=1/FAILURE. While upgrading I had an issue that meant I had to restart the box. Ran the yum-complete-transaction and then ran the update. All via the command line. Seemed to work.
Couldn’t sign into email and realised that sssd was not running, so no email received by the server or sent. Sending from external I get user unknown. Cannot connect to the mail server from any clients include SOGo.
Tried a few of the suggestions in the forum with no success.
Any help would be appreciated. Any information required can be provided.
Tried SSSD start failed after update - yum command. No luck
Did a config restore and no luck. Now I have more services not running, however the extra services did start manually. SSSD still fails.
Account-provider-test dump appears fine.
journalctl -M nsdc seems fine. both winbindd and smbd finished and ready to server connections
systemctl status -M nsdc samba - active
systemctl status nsdc - active
Nmap
PORT STATE SERVICE
53/tcp open domain
88/tcp open kerberos-sec
135/tcp open msrpc
139/tcp open netbios-ssn
389/tcp open ldap
445/tcp open microsoft-ds
464/tcp open kpasswd5
636/tcp open ldapssl
3268/tcp open globalcatLDAP
3269/tcp open globalcatLDAPssl
49152/tcp open unknown
49153/tcp open unknown
49154/tcp open unknown
Nethsever-sssd version nethserver-sssd-1.7.0-1.ns7.noarch
host
Using domain server:
Address: 192.168.1.2#53
Aliases:
_ldap._tcp.graeleah.com has no SRV record
Just tried /usr/sbin/sssd -l and received the following
[dp_module_open_lib] (0x0010): Unable to load module [ad] with path [/usr/lib64/sssd/libsss_ad.so]: libwbclient.so.0: cannot open shared object file: No such file or directory
[dp_target_init] (0x0010): Unable to load module ad
[be_process_init] (0x0010): Unable to setup data provider [1432158209]: Internal Error
[main] (0x0010): Could not initialize backend [1432158209]
The above was repeated 3 times then
[sssd] [monitor_restart_service] (0x0010): Process [domain.com], definitely stopped!
[sssd] [monitor_cleanup] (0x0010): Error removing pidfile! (2 [No such file or directory])
You probably have a broken link inside this dir /usr/lib64/samba/wbclient/.
I can’t say what is the correct fix without inspecting the machine, but you could try to:
