Hi to all.
On my testinstallation NS7A3 i recognised that sssd not starts.
output journalctl -xe
[root@test ~]# journalctl -xe
Jun 16 16:15:19 test.ns7a3.at systemd[1]: Started Authorization Manager.
– Subject: Unit polkit.service has finished start-up
– Defined-By: systemd
– Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
– Unit polkit.service has finished starting up.
– The start-up result is done.
Jun 16 16:15:19 test.ns7a3.at dbus-daemon[619]: dbus[619]: [system] Successfully activated service 'org.freedesktop.Poli
Jun 16 16:15:19 test.ns7a3.at polkitd[3865]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 16 16:15:19 test.ns7a3.at polkitd[3865]: Registered Authentication Agent for unix-process:3861:8481366 (system bus n
Jun 16 16:15:19 test.ns7a3.at systemd[1]: Starting System Security Services Daemon…
– Subject: Unit sssd.service has begun start-up
– Unit sssd.service has begun starting up.
Jun 16 16:15:19 test.ns7a3.at sssd[3874]: Starting up
Jun 16 16:15:19 test.ns7a3.at sssd[be[ns7a3.at]][3875]: Starting up
Jun 16 16:15:19 test.ns7a3.at sssd[be[ns7a3.at]][3876]: Starting up
Jun 16 16:15:21 test.ns7a3.at sssd[be[ns7a3.at]][3877]: Starting up
Jun 16 16:15:24 test.ns7a3.at sssd[nss][3878]: Starting up
Jun 16 16:15:24 test.ns7a3.at sssd[pam][3879]: Starting up
Jun 16 16:15:24 test.ns7a3.at sssd[pam][3880]: Starting up
Jun 16 16:15:24 test.ns7a3.at sssd[nss][3881]: Starting up
Jun 16 16:15:25 test.ns7a3.at sssd[be[ns7a3.at]][3882]: Starting up
Jun 16 16:15:25 test.ns7a3.at sssd[3874]: Exiting the SSSD. Could not restart critical service [ns7a3.at].
Jun 16 16:15:25 test.ns7a3.at systemd[1]: sssd.service: control process exited, code=exited status=1
Jun 16 16:15:25 test.ns7a3.at systemd[1]: Failed to start System Security Services Daemon.
– Subject: Unit sssd.service has failed
– Unit sssd.service has failed.
– The result is failed.
Jun 16 16:15:25 test.ns7a3.at systemd[1]: Unit sssd.service entered failed state.
Jun 16 16:15:25 test.ns7a3.at systemd[1]: sssd.service failed.
Jun 16 16:15:25 test.ns7a3.at polkitd[3865]: Unregistered Authentication Agent for unix-process:3861:8481366 (system bus
lines 1427-1465/1465 (END)
Jun 16 16:15:19 test.ns7a3.at dbus-daemon[619]: dbus[619]: [system] Successfully activated service 'org.freedesktop.PolicyKit1’
Jun 16 16:15:19 test.ns7a3.at polkitd[3865]: Registered Authentication Agent for unix-process:3861:8481366 (system bus name :1.71 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path
Jun 16 16:15:25 test.ns7a3.at polkitd[3865]: Unregistered Authentication Agent for unix-process:3861:8481366 (system bus name :1.71, object path /org/freedesktop/PolicyKit1/AuthenticationAge
Is this the reason i can not join/reach this AD?
Servicepanel shows sssd in red “stoped”.
Thanks for any answer.
Best regards.
