Hi Team,
I would like to asked if there is an option in SSL_Bump configuration that I can bypass all windows application that uses the internet like skype, dropbox etc? Thank you.
Regards,
Eliezer Ga
Hi Team,
Regards,
Eliezer Ga
Yes, you should modify the SSLBypass option:
http://docs.nethserver.org/projects/nethserver-devel/en/latest/web_proxy.html
Hi @giacomo Thank you for this but I am completely lost. Where can I find the fwrule? And can you give me example what do i need to encode ? Espacially windows applucation like skype amd dropbox? Thanks
You must add a list of domains as the option. Example:
config setprop SSLBypass dropbox.com,skype.com
signal-event nethserver-squid-update
The domain list depends on what servers each program try to access.
I tried it however it is not working in dropbox and skype client in windows
Absolutely, my bad! I was writing from my smartphone.
@eliezer.axiem try with this:
config setprop squid SSLBypass dropbox.com,skype.com
But you must take care to correctly fill the domain list.
Will try on this and give you feedback. Thank you
Is it worked? Please mark as solved
