I m using squid proxy & Web filter.
Now the senario is [ I WANT TRANSPARENT PROXY!!..]
1:When proxy is set to manual – every things works proper -websites-are blocked redirected and all…
2:When proxy set to authenticated – asks username password for every new tab (su**)
3:When set to transparent – HTTPS sites are not blocked eg: facebook ,gmail.
4:When set to transparent with ssl – HTTPS sites do not show up there content at all says untrusted certificate.
I have downloaded shalla blacklists and also filtered it .
Can you suggest me trick or hack or way to achive my requirements!!!
Hi @Tohid_Tamboli,
Pls. check out the query I recently raised. I have put there how I made it work. However, I do not have any authentication enabled so it might be different.
http://community.nethserver.org/t/proxy-configuration/741?source_topic_id=780
Hope it will help you somehow.
~Vhinz
vhinzsanchez: thank you very much !!!
You took me to a link that told me to auto detect proxy settings !
My settings on server side transparent ssl mode.
Browser set to auto-detect proxy
And the error on the browser is
Unable to find Proxy settings
for any site i request
but what settings were at server side ??
Hello @Tohid_Tamboli,
My server settings are set to Transparent with SSL as well selected the tickbox on Block HTTP and HTTPS ports.
On client-side, try auto-detect as well as other settings. Try with different browsers as well so you can thoroughly check if the issue is server or client-side configuration.
