Squid kerberos wpad ip instead fqdn
everything works fine if i use:
proxy.ant.gc:3128
when i use Windows autodetection to find the wpad file i got login pop up from proxy, reason is because wpad.dat show ip’s instead fqdn of proxy:
function FindProxyForURL(url, host)
// Direct access to localhost
if (isInNet(host, “127.0.0.1”, “255.255.255.255”))
return “DIRECT”;
// Direct access to local hosts
if (isPlainHostName(host))
    return "DIRECT";
// eth0:192.168.208.0 green authenticated
if (isInNet(myIpAddress(), "192.168.208.0", "255.255.255.0"))
    return "PROXY 192.168.208.11:3128";
// DEFAULT
i checked the template /etc/e-smith/templates/var/www/html/wpad.dat/70proxyMode:
so it seems my variable $adJoin is 0, but why?
i successfully joind to my external samba domain, i see users and groups etc…
Thx!
welcome to NethServer Community.
You may use custom templates:
