Just noticed that about two days ago Suricata had failed, and doesn’t want to run again. I am not sure what broke, but it would appear an update I did two days is the culprit.
The last suricata block entry was on 2020-10-05 21:06, and the update was performed at 2020-10-05 21:12. Since then no enteries are logged, so I assume the service failed after the update.
The error shows up as:
Oct 07 10:11:28 nethserver.triggeredstudios.com systemd[1]: Starting Suricata Intrusion Detection Service...
Oct 07 10:11:28 nethserver.triggeredstudios.com systemd[1]: Started Suricata Intrusion Detection Service.
Oct 07 10:11:28 nethserver.triggeredstudios.com suricata[15979]: 7/10/2020 -- 10:11:28 - <Error> - [ERRCODE: SC_ERR_INVALID_ARGUMENT(13)] - too much Netfilter queue registered (16)
Oct 07 10:11:28 nethserver.triggeredstudios.com systemd[1]: suricata.service: main process exited, code=exited, status=1/FAILURE
Oct 07 10:11:28 nethserver.triggeredstudios.com systemd[1]: Unit suricata.service entered failed state.
Oct 07 10:11:28 nethserver.triggeredstudios.com systemd[1]: suricata.service failed.
I tried updating Nethserver completely and doing a full reboot, and also tried disabling all Suricata rulesets and restarting Suricata, but I always get the same error. My Google-fu has come up broke.
Everything else seems to be working, and Suricata is the only failed service.
Yum history output from upgrade that seems to have broke things:
Transaction ID : 13
Begin time : Mon Oct 5 21:12:41 2020
Begin rpmdb : 1053:f5142f7c7980526bf0da45861864b8edddacc5a7
End time : 21:14:12 2020 (91 seconds)
End rpmdb : 1053:8ac703cb6265b5d3b56cac9eb4dcf2db6bde758f
User : root <root>
Return-Code : Success
Command Line : update
Transaction performed with:
Installed rpm-4.11.3-43.el7.x86_64 @anaconda
Installed yum-3.4.3-167.el7.centos.noarch @anaconda
Installed yum-plugin-fastestmirror-1.1.31-54.el7_8.noarch @ce-updates
Packages Altered:
Updated arp-scan-1.9.2-1.el7.x86_64 @nethserver
Update 1.9.7-3.el7.x86_64 @epel
Updated ndpi-3.2.0-2841.x86_64 @ntop
Update 3.2.0-2861.x86_64 @ntop
Updated nethserver-cockpit-1.7.7-1.ns7.noarch @nethserver-updates
Update 1.7.8-1.ns7.noarch @nethserver-updates
Updated nethserver-cockpit-lib-1.7.7-1.ns7.noarch @nethserver-updates
Updated nethserver-fail2ban-1.5.0-1.ns7.noarch @nethserver-updates
Update 1.5.2-1.ns7.noarch @nethserver-updates
Updated nethserver-firewall-base-3.11.2-1.ns7.noarch @nethserver-updates
Update 3.12.2-1.ns7.noarch @nethserver-updates
Updated nethserver-firewall-base-ui-3.11.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-common-2.17.2-1.ns7.noarch @nethserver-updates
Update 2.17.3-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-filter-2.17.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-getmail-2.17.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-imapsync-2.17.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-server-2.17.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mail-smarthost-2.17.2-1.ns7.noarch @nethserver-updates
Updated nethserver-mattermost-1.5.1-1.ns7.x86_64 @nethserver-updates
Update 1.5.2-1.ns7.x86_64 @nethserver-updates
Updated nethserver-openssh-1.6.0-1.ns7.noarch @nethserver-updates
Update 1.7.0-1.ns7.noarch @nethserver-updates
Updated nethserver-pulledpork-2.1.6-1.ns7.noarch @nethserver-updates
Obsoleting nethserver-pulledpork-2.1.7-1.ns7.noarch @nethserver-updates
Updated nethserver-stephdl-1.1.1-1.ns7.sdl.noarch @/nethserver-stephdl-1.1.1-1.ns7.sdl.noarch
Update 1.1.2-1.ns7.noarch @stephdl
Updated nethserver-subscription-3.6.4-1.ns7.noarch @nethserver-updates
Update 3.6.5-1.ns7.noarch @nethserver-updates
Updated nethserver-subscription-inventory-3.6.4-1.ns7.x86_64 @nethserver-updates
Update 3.6.5-1.ns7.x86_64 @nethserver-updates
Updated nethserver-subscription-ui-3.6.4-1.ns7.noarch @nethserver-updates
Updated nethserver-suricata-2.1.2-1.ns7.noarch @nethserver-updates
Update 2.2.0-1.ns7.noarch @nethserver-updates
Updated ntopng-4.0.200923-9285.x86_64 @ntop
Update 4.0.201005-9285.x86_64 @ntop
Updated ntopng-data-4.0.200923-9285.noarch @ntop-noarch
Update 4.0.201005-9285.noarch @ntop-noarch
Updated olefy-1.2.0-1.ns7.x86_64 @nethserver-updates
Update 1.2.1-1.ns7.x86_64 @nethserver-updates
Updated pfring-7.6.0-3176.x86_64 @ntop
Update 7.6.0-3203.x86_64 @ntop
Obsoleted pulledpork-0.7.4-1.el7.noarch @epel
Dep-Install pulledpork7-0.7.3-7.ns7.noarch @nethserver-updates
Updated radcli-1.2.11-1.el7.x86_64 @epel
Update 1.2.12-1.el7.x86_64 @epel
Scriptlet output:
1 Received an unexpected HTTP status code of 401 from https://updates.maxmind.com/app/update_secure?db_md5=00000000000000000000000000000000&challenge_md5=44bd2679ddfb43e2533f6e0a59126fae&user_id=0&edition_id=GeoLite2-Country:
2 Invalid account ID
3
4 geoipupdate 2.5.0
5 Opened License file /etc/GeoIP.conf
6 AccountID 0
7 LicenseKey 000000000000
8 Insert edition_id GeoLite2-Country
9 Insert edition_id GeoLite2-City
10 Read in license key /etc/GeoIP.conf
11 Number of edition IDs 2
12 url: https://updates.maxmind.com/app/update_getfilename?product_id=GeoLite2-Country
13 md5hex_digest: 00000000000000000000000000000000
14 url: https://updates.maxmind.com/app/update_getipaddr
15 Client IP address: 71.214.94.211
16 md5hex_digest2 (challenge): 44bd2679ddfb43e2533f6e0a59126fae
17 url: https://updates.maxmind.com/app/update_secure?db_md5=00000000000000000000000000000000&challenge_md5=44bd2679ddfb43e2533f6e0a59126fae&user_id=0&edition_id=GeoLite2-Country
18
19 To use geolocation in ntop products, follow the instructions at
20 https://github.com/ntop/ntopng/blob/dev/doc/README.geolocation.md
21 warning: /etc/pulledpork/pulledpork.conf created as /etc/pulledpork/pulledpork.conf.rpmnew
22 Setting up redis auto startup
23 Note: Forwarding request to 'systemctl enable redis.service'.
24 Creating link under /usr/local/bin
history info
