[SOLVED] SOGo Authentication problem
Installed NS 7 RC3 interactive install, setup with nethserver-dc, email, file server, SOGo, vpn, jabber, …
Imported users and emails with the sssd scripts, now when I want to access the SOGo application I get a message saying : Authentication Failed - Incorrect username or password.
With this messages in /var/log/sogo/sogo.log
Jan 03 14:27:44 sogod [27844]: 172.17.0.101 "GET /SOGo/ HTTP/1.1" 200 7093/0 0.026 22385 68% 0 Jan 03 14:27:53 sogod [27844]: <0x0x7f7c11850270[LDAPSource]> <NSException: 0x7f7c127ddc50> NAME:LDAPException REASON:operation bind failed: Invalid credentials (0x31) INFO:{"error_code" = 49; login = "samaccountname=indra,cn=users,dc=noble-house,dc=tk"; } Jan 03 14:27:53 sogod [27844]: [ERROR] <0x0x7f7c11b9d6c0[LDAPSource]> Could not bind to the LDAP server ldaps://noble-house.tk (389) using the bind DN: NOBLE-HOUSEGANESHA$ Jan 03 14:27:53 sogod [27844]: [ERROR] <0x0x7f7c11b9d6c0[LDAPSource]> <NSException: 0x7f7c1276f690> NAME:LDAPException REASON:operation bind failed: Invalid credentials (0x31) INFO:{"error_code" = 49; login = "NOBLE-HOUSEGANESHA$"; } Jan 03 14:27:53 sogod [27844]: SOGoRootPage Login from '172.17.0.101' for user 'indra' might not have worked - password policy: 65535 grace: -1 expire: -1 bound: 0 Jan 03 14:27:53 sogod [27844]: 172.17.0.101 "POST /SOGo/connect HTTP/1.1" 403 34/62 0.078 - - 0
Please see:
Edit: @mark_nl can we release latests packages? Can you do that?
Updated nethserver-sogo from nethforge-testing,
login authentication working after restarting service and reloading page.
:heart_eyes:
Hi @indra
if you believe that the problem has been solved, please mark as solved the answer that helped you. This helps those who have the same problem.
Thanks :wink:
Euh yes, would love to, but how :innocent:
Like so?
Read this:
found it :slight_smile:
I have somehow got the same issue after rebuilding my nethserver? Can someone please tell me how they solved this problem?
I just updated nethserver-sogo from testing repo’s, but that was 3 months ago. Updated nethserver-sogo will already be in the normal repo’s. I guess you got a different problem or used an old install media (cd/usb).
If updating doesn’t solve it, get logs from /var/log/sogo/sogo.log and maybe /var/log/messages, and start a new topic?
I installed nethserver from the latest iso downloaded yesterday. I was battling to get the domain controller to work because before yesterdays update when creating the active directory domain controller and leaving the hostname as “ad” in the past used to append this ad to the email in sogo.
To get around the bug I used to install active directory without the hostname this soved my problem. It seems nethserver have now fixed the bug and now require the hostname which is hidden in sogo now and does not append to the email address anymore.
